y7 and z6 cam gears the same???????? need to know
all right i just got a cam gear (aem tru-time adj) and it came off of a d16y7, i was going to get the y7 for free and then i decided that i need the extra space for my b-series build im going to try.
i have a 95 civic with a d16z6 will the d16y7 cam gear work with the motor or are they different
Re: y7 and z6 cam gears the same???????? need to know (ventturei27)
i think there different..count the number of tooths on both cam gears to make sure..
Well technically they're different parts (different part numbers) though I'm not sure as to the diameter of the pulley & the # of teeth.
I'd be lying if I said I knew if they were interchangeable or not.
lol its 11:18 cant call aem and i wanted to install this tonight, lol
o wellif anyone knows for sure that would be great, i dont want to start pulling off everything to find out it wont work...
Re: (ventturei27)
If anything the timing will be off a few degrees. I know that if you put a z6 cam in a y8, you'll need an adjustable cam gear to adjust it like 3 degrees.
Just put it on and put everything at top dead center and see what happens...
lol- just see what happens- ive seen some bad stuff happen from that phrase
id rather just know if they are the same, cause if i have to adjust the cam gear by 3-4.58 just to get it normal there no point in putting it on for .5 of a degree
mycvc8u2
11-13-2003 01:51 AM
