Misfire problem, can anyone help?
Old May 21, 2005 | 08:02 AM
Turd Furgeson's Avatar
Default Misfire problem, can anyone help?
Hey all. I am going nuts over here trying to fix this. I have a 98 civic EX. It's throwing 5 codes. P0301, 0302,0303,0300 one for each cylinder misfire. Then a P1399 for a random ignition misfire. I changed plugs, wires, cap and rotor, cleared the codes, and the problem is still there. I searched, but haven't found anything to help. Any ideas?? Help is much appreciated. Thanks!
Old May 21, 2005 | 08:13 AM
SOHCmaster's Avatar
sure you didnt jump time ?
Old May 21, 2005 | 10:38 AM
Default Re: (PK SPEED)
I kind of thought that at first. I just did a compression check, approx 170 in all 4 cylinders. If it jumped time, wouldn't the compression be lower?
Old May 21, 2005 | 05:41 PM
anyone else?
Old Sep 24, 2005 | 01:31 PM
H22a4u's Avatar
Default Re: (Turd Furgeson)
did u have the coil tested? if all the cyls are misfiring, it would be something that affects all cyls. cap and rotor are unlikely but inexpensive to replace, coil is about 35 bucks from autozone, they can test yours there as well
ribal_gh
Aug 15, 2014 06:04 PM
SovereignAce
Jul 1, 2013 03:32 AM
wickidnis
Apr 5, 2010 07:11 AM
BEE1
Oct 26, 2005 03:22 PM
