oil pump question?
Old May 20, 2005 | 07:53 PM
chadwick16's Avatar
Default oil pump question?
should i replace the seals of the oil pump of a b-series engine?
Old May 20, 2005 | 08:51 PM
s2kdre's Avatar
Default Re: oil pump question? (chadwick16)
you can reuse them if they look good.
Old May 20, 2005 | 09:00 PM
chadwick16's Avatar
Default Re: oil pump question? (jdmhonda)
first time engine builder. what looks good for seals?
Old May 21, 2005 | 06:09 AM
Takumi Fujiwara's Avatar
personally, I wouldn't use a used oil pump. If you're going to use one, change the seal, it's so cheap... this IS the oil PUMP after all.
Old May 21, 2005 | 06:10 AM
IN VTEC's Avatar
You can reuse o-rings if they aren't real hard, cracking, torn, broken, pinched, or flattened/permanently deformed too much.
When in doubt, replace it anyways.
There's only one o-ring on the oil pump. It's used to seal the pressurized side that feeds the main oil gallery that goes to the oil filter.
Old May 21, 2005 | 09:08 AM
s2kkid's Avatar
Default Re: oil pump question? (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">You can reuse o-rings if they aren't real hard, cracking, torn, broken, pinched, or flattened/permanently deformed too much.
There's only one o-ring on the oil pump. It's used to seal the pressurized side that feeds the main oil gallery that goes to the oil filter.</TD></TR></TABLE>
You can take your pump to the parts store and pick up an exact fit o-ring for .43 cents.
I saw hondas price of 2 bucks i was like what the hell. Ive used an exact fit o-ring picked up from the parts store several times with no problem at all. Everytime I have torqued down the oil pump It always distorted my O-ring.
So If I Were you, Is .43 cents worth knowing your pump wont leak pressure? If so make a run to the parts store.
Old May 21, 2005 | 10:40 AM
DAguyLS's Avatar
yes i'd replace also. Too simple not too.
somick
Aug 15, 2017 08:14 AM
caspers_hatch
Nov 12, 2005 11:37 PM
SleepyHF
Mar 15, 2004 08:26 PM
kerby116
Mar 1, 2004 03:34 AM
