96 gsr burn-out test
Old May 20, 2005 | 04:10 PM
951dc5's Avatar
Default 96 gsr burn-out test
when burn-out, does 2 front tires spin or it's just the passenger side spin? I did a burn-out test and i saw two marks on the ground. did i have lsd or is it normal for a take off??
Old May 20, 2005 | 04:27 PM
numbnuts22715's Avatar
should be both i think... You shouldnt have an LSD on your gsr unless you or someone else put it there.
Old May 20, 2005 | 04:36 PM
tWixT's Avatar
Default Re: 96 gsr burn-out test (Prelude951)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude951 &raquo;</TD></TR><TR><TD CLASS="quote">when burn-out, does 2 front tires spin or it's just the passenger side spin? I did a burn-out test and i saw two marks on the ground. did i have lsd or is it normal for a take off??</TD></TR></TABLE>
Both wheels will spin, but w/o the lsd your right front wheel should spin faster i do believe. Which is why when you do a nice smooth quick shift from 8200k in first to 2nd your car jerks to the right
Old May 20, 2005 | 06:39 PM
iconz116's Avatar
Default Re: 96 gsr burn-out test (tWixT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tWixT &raquo;</TD></TR><TR><TD CLASS="quote">
Both wheels will spin, but w/o the lsd your right front wheel should spin faster i do believe. Which is why when you do a nice smooth quick shift from 8200k in first to 2nd your car jerks to the right </TD></TR></TABLE>
Now i get it!
Old May 22, 2005 | 07:41 PM
951dc5's Avatar
Default Re: 96 gsr burn-out test (iconz116)
oh okay so it should be normal for 2 tires to spin on a take-off, then afterward it stops.. and only 1 tire spins from there..
Old May 22, 2005 | 09:08 PM
brad.'s Avatar
burn..out..TEST?
wayne0099
Aug 23, 2006 06:17 PM
kb58
11
Mar 19, 2005 07:12 AM
turbotime
Jul 29, 2004 10:03 AM
JunIntegra
Aug 24, 2003 01:05 PM
johnzm
Sep 14, 2002 07:11 PM
