What lug nut is good to use with ARP extended lugs?
Old May 20, 2005 | 03:50 PM
jimmhatch's Avatar
Default What lug nut is good to use with ARP extended lugs?
I was just curious because theres not much lugs nuts out there to use besides some of the open ended ones. Is there any lug nut lock out there to use with ARP extended lugs?
Old May 20, 2005 | 05:32 PM
TallAssFilipino's Avatar
Default Re: What lug nut is good to use with ARP extended lugs? (jimmhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jimmhatch &raquo;</TD></TR><TR><TD CLASS="quote">I was just curious because theres not much lugs nuts out there to use besides some of the open ended ones. Is there any lug nut lock out there to use with ARP extended lugs?</TD></TR></TABLE>
BUMP.
Old May 21, 2005 | 01:25 AM
jimmhatch's Avatar
Default Re: What lug nut is good to use with ARP extended lugs? (MDJ IKNJ)
anyone?
Old May 21, 2005 | 02:43 AM
drevinder's Avatar
any open end lug nut's would work...there are oem open end lug nut's as well...i used few close end but chopped the end's off so i can run hubcaps on mine for the winter.....
Old May 21, 2005 | 03:07 AM
longbeachpurplecivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jimmhatch &raquo;</TD></TR><TR><TD CLASS="quote">lug nut lock </TD></TR></TABLE>
he was askng for that man... none that i know of
Old May 21, 2005 | 03:15 AM
drevinder's Avatar
Default Re: What lug nut is good to use with ARP extended lugs? (longbeachpurplecivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by longbeachpurplecivic &raquo;</TD></TR><TR><TD CLASS="quote">
he was askng for that man... none that i know of </TD></TR></TABLE>
my bad ...i guess i need to sleep...nope i have not seen any ...i'm using gorilla's...on mine....yeah it take's a key ....is that what he is talking about ??
here ... http://www.steeda.com/store/fo...t.htm
http://upgrademotoring.com/wheels/lugnuts.htm
Old May 21, 2005 | 03:19 AM
Default Re: What lug nut is good to use with ARP extended lugs? (drevinder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drevinder &raquo;</TD></TR><TR><TD CLASS="quote">
i guess i need to sleep</TD></TR></TABLE> lol. like how the stock one has regular nuts and a lock one
Old May 21, 2005 | 04:29 PM
Motor-Tek's Avatar
Kyokugen makes open-ended locking nuts
B2FiNiTY's Avatar
zenki
Old May 21, 2005 | 05:16 PM
jimmhatch's Avatar
Default Re: What lug nut is good to use with ARP extended lugs? (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Motor-Tek &raquo;</TD></TR><TR><TD CLASS="quote">Kyokugen makes open-ended locking nuts</TD></TR></TABLE>
they strip all the time
Old May 21, 2005 | 05:21 PM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jimmhatch &raquo;</TD></TR><TR><TD CLASS="quote">they strip all the time</TD></TR></TABLE>
i haven't had any problem with the lugs themselves, but the lug key i have is almost rounded out.
HondamanXxX
Oct 9, 2007 10:17 AM
Cliffjumper2
May 30, 2005 08:14 AM
Halo
Feb 1, 2005 04:34 PM
S13 slide
Nov 11, 2003 01:44 PM
