95 LS WITH CHIPPED ECU...ANYONE RUNNING THIS
Old May 20, 2005 | 11:14 AM
bottlefed13's Avatar
Default 95 LS WITH CHIPPED ECU...ANYONE RUNNING THIS
just wondering if there was anyone out there that has done this. if so, what were you mods? thanks.
Old May 20, 2005 | 11:29 AM
Kendall's Avatar
I don't know if I'm quite getting what you're saying, or if you're not quite getting what you're asking, but you would burn the chip for the mods you have. It's been done countless times in the past with every combination of mods from stock to fully built turbo cars.
Old May 20, 2005 | 11:32 AM
Default Re: (Kendall)
just asking about stock cars. would a chipped ecu help out, or would it be worthless?
Old May 20, 2005 | 11:43 AM
Kendall's Avatar
Well, you could always lean it out a bit and increase your gas milage.
Old May 20, 2005 | 11:53 AM
would the car improve at all with a chipped ecu on a stock motor?
Old May 20, 2005 | 12:03 PM
Medek's Avatar
Default Re: (bottlefed13)
Not really, most "pre-made" chips you find on ebay and so on are pretty much junk. The idea behind a burned chip is unique for each car. Where you are at now as a tuner, and parts wise (stock, almost stock) A chip is unessacery. I think you would get more of a satisfaction with an Apexi SAFC. It's a little blue box that connects to your ecu and it allows you to adjust fuel% at differant rpm points. That will allow you to "lean out" as previously mentioned. And to sorta "self-adjust things" as your experience and your parts grow.
Old May 20, 2005 | 12:06 PM
Default Re: (Medek)
hey thanks for the replys. what's the advantages of leaning out?
Old May 23, 2005 | 11:57 AM
Medek's Avatar
just better gas mileage at stock/ near stock level. running lean is devastating if you were say squeezing NOS or boosting. just means yor runing a smaller % of fuel from the injectors.
Old May 23, 2005 | 01:00 PM
no2unenolife's Avatar
i ran a chipped ecu from ebay, cams and all that crap, waste of money cuz its from ebay, then i got a safc and was tuned properly and i'm way happy with that. now i'm boosted and i've bought my self a chip burner to do my own tuning and make my own chips
Old May 23, 2005 | 02:55 PM
hybrid_vtec's Avatar
Default Re: (no2unenolife)
I am chipped and SAFC-II tuned, and I am happy. Made 25 whp from fuel tuning on the dyno!
Next tune though is going to be with Crome, but I will still use the SAFC-II as well unless it makes no difference!
Old May 25, 2005 | 03:36 PM
thanks everyone.
Organization
Engine Management and Tuning
20
Sep 11, 2011 03:37 AM
tubed-ef
May 2, 2007 11:35 AM
loner714
Feb 26, 2007 04:54 PM
95lscivic
Aug 19, 2006 09:09 AM
J.nguyen
Sep 26, 2005 01:48 PM
