Need info onB18C5 turbo!!
Old Feb 5, 2002 | 09:12 PM
MUGENTYPER's Avatar
Default Need info onB18C5 turbo!!
wassup! i got rid of my NOS and planning to go force induction on my type-r engine(B18C5)! what's the best performance parts for turbo should i get? i wanna go higher compression and turbo, is this possible?? please help!!!
_______
Old Feb 5, 2002 | 09:30 PM
gcajnr21's Avatar
Default Re: Need info onB18C5 turbo!! (MUGENTYPER)
hey mugen man just do a search and you will be set free!! i'm new in this post and i found everything out by searching for it first!! so give it a try and im sure you will find the best setup for your application.
Old Feb 5, 2002 | 09:40 PM
austrian type-R's Avatar
Default Re: Need info onB18C5 turbo!! (gcajnr21)
You wanna go higher compression and turbo
The compression is already very high (10.6:1) and you canīt boost more than 7-8psi SAFE on the stock bottom end until you lower the cr. You want a standalone ECU too for a good setup.
Go with custom or DRAG III kit
Old Feb 5, 2002 | 10:16 PM
1fstevo's Avatar
New User
henchie
Mar 28, 2016 07:20 AM
CXtypeR
Feb 28, 2007 10:44 PM
Jxi8s2k
Honda S2000
23
Dec 12, 2005 05:53 AM
Doug684
Dec 30, 2003 09:59 AM
MUGENTYPER
Feb 6, 2002 06:31 AM
