need help with d15b with d16z6 head swap
Old May 20, 2005 | 09:08 AM
hatch b16a guy's Avatar
Default need help with d15b with d16z6 head swap
i bought a d16z6 head for my d15b and i need help running the vtec
i was told i will need an ex ecu and a ex timming belt
Old May 20, 2005 | 11:04 AM
hookedonvtec's Avatar
Default Re: need help with d15b with d16z6 head swap (hatch b16a guy)
i have a p28 manual ecu if u want it. 50 shipped
Old May 20, 2005 | 11:38 AM
dogfood's Avatar
you will definately need the ex ecu, and you can get away with running just the vtec wires, do a search and you should be able to find the right pin outs.
Old May 20, 2005 | 01:26 PM
Ignitecivic's Avatar
Default Re: need help with d15b with d16z6 head swap (dogfood)
You’ll need to run the blue wire (or whichever color is from the plug) to pin D6, and then run the black ground wire from the plug to anywhere on the motor. You then need to run the green wire from the VTEC solenoid to pin A4.
if ur using a 4 wires o2 sensor u will need to run that into the p28 ecu as well. cuz the p28 read 4 wires o2 instead of 1 wires like the p08
Old May 20, 2005 | 02:33 PM
integraXTC's Avatar
search the faq.
Yurei
May 5, 2012 01:51 PM
whatzthadilly
Oct 2, 2009 09:06 AM
no_rice_please
Feb 25, 2007 07:29 PM
pinecone
Mar 18, 2006 02:30 PM
tolowhb
10
Aug 5, 2003 07:21 PM
