horn stoped working in my ek??
Old May 20, 2005 | 04:08 AM
ReDHaTcHyGuy's Avatar
Default horn stoped working in my ek??
i was driving the other day and i wend to beep at one of my friends and my horn doesn't work now in my 97 hatch...... It just worked the day before... i checked the fuse it didn't look blown , i may replace it for the heck of it ..... i dunno if there is some sort of relay or anything ... any idea's
Old May 20, 2005 | 04:25 AM
tEhNgUyeN's Avatar
Default Re: horn stoped working in my ek?? (ReDHaTcHy97)
maybe its a fuse.. since i was looking through my 99/00 civic hatchback manual and saw it list a fuse for the horn button?
Old May 20, 2005 | 06:17 AM
Default Re: horn stoped working in my ek?? (tEhNgUyeN)
i checked the underhood fuse for the horn , it didn't look blown , i may replace for the heck of it
Old May 20, 2005 | 06:57 AM
Cwhiteg6's Avatar
my friend has this similar problem in his 00 integra gsr. it isnt the fuses because we checked alll of them.
i really wanna know this one too????
Old May 22, 2005 | 08:36 PM
Default Re: horn stoped working in my ek?? (civtecek9)
bump for more info
Old May 22, 2005 | 08:44 PM
soberstan's Avatar
my 1995 hatch had the same problem....right wen i got my car back from the shop...(swap, suspension, paint job..did it all at once)...my horn didnt work....i kept pushing the horn button cus i kept forgetting it wasnt working and after about a week or two...it just started workign again....
Old May 22, 2005 | 10:43 PM
balistik's Avatar
Same thing happened to me but i figured out that it was my cruise control switch. I swapped my steering wheel with the jspec one and had to move my cruise. Whenever the cruise control isn't plugged in the horn works. viceversa. i have a 93 si.
Old May 22, 2005 | 11:19 PM
SlowCGP_EJ8's Avatar
Bump for same problem..
Old May 23, 2005 | 01:26 AM
civiccoupe94's Avatar
happened to some dude in my old school.. he then got a horn from a pickup truck from the junk yard.. its pretty funny.. honk at people and they think its a truck or something big.. then its like man its a little hatch
Old May 23, 2005 | 06:53 AM
BringUDwn's Avatar
seems like a blown horn thats it,.... juste replace it...u can try to put a direct line from the horn to the battery see if its working or not.. if not just replace it
Old May 23, 2005 | 07:10 AM
Default Re: (BringUDwn)
yeah i may try that
Old May 23, 2005 | 09:25 AM
Grimm's Avatar
Default Re: (ReDHaTcHy97)
do you have a SRS light on?
It could also be a cable reel problem in your steering column.
Old May 23, 2005 | 09:33 AM
Calvinator's Avatar
Default Re: (Grimm)
bump because mines only works sometimes.
Old May 23, 2005 | 09:36 AM
Default Re: (Grimm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grimm &raquo;</TD></TR><TR><TD CLASS="quote">do you have a SRS light on?
It could also be a cable reel problem in your steering column. </TD></TR></TABLE>
the srs light is on but that is only because i put a Si steering wheel on , but that was months ago , i ran the car without the airbag in to make sure i had the splines lined up, and i haven't gotten the light reset yet
Old May 23, 2005 | 10:06 AM
91integraLSVTEC's Avatar
i have the same problem with my 95 ex coupe. the horn only works if i turn the steering wheel. it cant be a fuse probably if the fuse is not blown someone had to have had this problem and fixed it??
Old May 23, 2005 | 10:57 AM
TsukubaDreams's Avatar
I have the same problem. My car got stolen and i got it back. They had to replace the steering colum and now my horn dont work so i use the finger now and some water baloons. Im just going to turn it into a 2stage ingition button. Horns are over rated anyways. Good luck.
Old May 23, 2005 | 11:06 AM
Tim.'s Avatar
yall ran out of hornage hahahaa
Old May 23, 2005 | 11:25 AM
ninjastance_batmang's Avatar
Default Re: (spoon0313)
blah, u dont need a horn, just yell at people with a horrible look on your face.
Old May 23, 2005 | 11:54 AM
Grimm's Avatar
Default Re: (91integraLSVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91integraLSVTEC &raquo;</TD></TR><TR><TD CLASS="quote">i have the same problem with my 95 ex coupe. the horn only works if i turn the steering wheel. it cant be a fuse probably if the fuse is not blown someone had to have had this problem and fixed it??</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TsukubaDreams &raquo;</TD></TR><TR><TD CLASS="quote">I have the same problem. My car got stolen and i got it back. They had to replace the steering colum and now my horn dont work so i use the finger now and some water baloons. Im just going to turn it into a 2stage ingition button. Horns are over rated anyways. Good luck.</TD></TR></TABLE>
check the cable reel...
Old Jun 9, 2005 | 09:44 PM
integraXTC's Avatar
Default Re: (Grimm)
sometimes u need the horn for coming out of alleys. I need my horn.
cars
10
Aug 3, 2010 03:30 PM
hans stoner
Oct 2, 2006 06:11 AM
kupras
Dec 11, 2003 01:13 PM
NiCkArInO
May 11, 2003 09:13 AM
