Flaring factory OEM brake lines?
Old May 20, 2005 | 12:29 AM
Pandahatch's Avatar
Default Flaring factory OEM brake lines?
I'm in the process of relocating my proportioning valve and have everything done except for the rear lines. I wanted adapt 3AN Earl's line to the existing rear brake lines but I'm running into a problem flaring the lines. Everytime I try to flare it with the double flaring tool, it just pushes the line through the clamp. Is there a trick to this or am I screwed having to run all new rear lines. Thanks.
Old May 20, 2005 | 11:42 AM
Pandahatch's Avatar
UP
Old May 20, 2005 | 01:01 PM
suspendedHatch's Avatar
Default Re: (PandaHatch)
Flaring hard lines is a true pain in the ***. I'd rather replace the whole **** with SS braided. Good luck.
Take it to a shop that does a lot of old car restorations. They do those hard lines all the time.
Old May 20, 2005 | 02:11 PM
Pandahatch's Avatar
Yes it is. Is there a special tool that can do it besides a regular double flare hand tool?
Old Jul 2, 2023 | 09:06 PM
JCTyler's Avatar
Default Re: Flaring factory OEM brake lines?
I'm trying to do my lines myself and have had no luck with ths tool for making the double flare. It is a Titan 51535 3/16 in. Double Flaring Tool, after seeing the positive reviews and how easy the tool is to use. I followed instructions and made 4 flare attempts, all lobisded failures. Has anyone else tried this?
Marvin1985
Suspension & Brakes
Jan 15, 2014 08:22 PM
rhdekhatchie
Suspension & Brakes
Dec 11, 2008 07:31 AM
94CivicSi
18
Mar 28, 2008 05:03 AM
EgSalad
Jul 19, 2006 08:41 PM
Pandahatch
Suspension & Brakes
May 22, 2005 11:28 AM
