Flaring factory OEM brake lines?
I'm in the process of relocating my proportioning valve and have everything done except for the rear lines. I wanted adapt 3AN Earl's line to the existing rear brake lines but I'm running into a problem flaring the lines. Everytime I try to flare it with the double flaring tool, it just pushes the line through the clamp. Is there a trick to this or am I screwed having to run all new rear lines. Thanks.
Re: (PandaHatch)
Flaring hard lines is a true pain in the ***. I'd rather replace the whole **** with SS braided. Good luck.
Take it to a shop that does a lot of old car restorations. They do those hard lines all the time.
Re: Flaring factory OEM brake lines?
I'm trying to do my lines myself and have had no luck with ths tool for making the double flare. It is a Titan 51535 3/16 in. Double Flaring Tool, after seeing the positive reviews and how easy the tool is to use. I followed instructions and made 4 flare attempts, all lobisded failures. Has anyone else tried this?
Marvin1985
Suspension & Brakes
01-15-2014 08:22 PM
94CivicSi
18
03-28-2008 05:03 AM
