Suspension & Brakes Theory, alignment, spring rates....
Flaring factory brake lines?
Old May 20, 2005 | 12:25 AM
Pandahatch's Avatar
Default Flaring factory brake lines?
I'm in the process of relocating my proportioning valve and have everything done except for the rear lines. I wanted adapt 3AN Earl's line to the existing rear brake lines but I'm running into a problem flaring the lines. Everytime I try to flare it with the double flaring tool, it just pushes the line through the clamp. Is there a trick to this or am I screwed having to run all new rear lines. Thanks.
Old May 20, 2005 | 11:41 AM
Pandahatch's Avatar
Default Re: Flaring factory brake lines? (PandaHatch)
TTT
Old May 20, 2005 | 12:25 PM
MattD@Stoptech's Avatar
You're doing something wrong or using a wrong/bad tool....they can be re-flared just fine.
Old May 20, 2005 | 02:10 PM
Pandahatch's Avatar
No they can't trust me here. I've tried doing a regular flare to them also and the metal is too damn hard.
Old May 20, 2005 | 03:01 PM
Default Re: (PandaHatch)
Trust you with what?
I've flared the stock lines...
Old May 20, 2005 | 05:52 PM
Pandahatch's Avatar
With what? Care to share here. I took the factory line to a hydraluic line shop here and they couldn't even do it with the regular double flare tool.
Old May 20, 2005 | 10:11 PM
I used a regular flaring tool, nothing special or particular. Wasn't any harder than flaring lines that you can get from autozone.
How are you cutting the line, maybe that's the problem. Maybe you're getting the line out of round when cutting...
Old May 20, 2005 | 11:13 PM
Pandahatch's Avatar
I used a tubing cutter to cut it, it's perfect. I couldn't even put a regular flare in it it is so tough. There's something up with it.
Old May 22, 2005 | 08:54 AM
.RJ's Avatar
.RJ
Bevel the line a bit on the edge before you flare it
Old May 22, 2005 | 11:28 AM
Pandahatch's Avatar
Already tried that.
Pandahatch
Jul 2, 2023 09:06 PM
Marvin1985
Suspension & Brakes
Jan 15, 2014 08:22 PM
94CivicSi
18
Mar 28, 2008 05:03 AM
JCracer723
Mar 9, 2007 06:52 AM
jolt-tsp
20
Sep 2, 2003 10:10 AM
