Safc values
Old May 19, 2005 | 07:33 PM
DarkDragon's Avatar
Default Safc values
on a S-AFC when it shows a neg. value is it adding or taking away fuel? i thought the + values would be adding fuel but when people boost they set it to -40 so im confuesed
Old May 19, 2005 | 08:15 PM
Deluzional's Avatar
Default Re: Safc values (DarkDragon)
its bc people are running larger injectors
Old May 19, 2005 | 09:21 PM
Cyclone's Avatar
when you put larger injectors more gas is being used .. so you would have to restrict the amount of fuel .. to a level that is preferable .. in most case's setting afc units to neg settings ..
Old May 20, 2005 | 03:18 AM
DarkDragon's Avatar
Default Re: (Cyclone)
ok that makes sence, so positive is adding fuel and negative would be taking away with stock injectors but with the 450 injectors since they are to large the duty cycle must be cut -40
roachsboosted16
Jan 27, 2011 10:09 AM
85
Honda Motorcycles
Feb 13, 2007 08:30 AM
Thumper!
May 24, 2004 11:49 AM
adhana2
May 22, 2003 05:26 PM
