Which fuse to pull for compression test on D16Z6?
Old May 19, 2005 | 05:36 PM
discrete's Avatar
Default Which fuse to pull for compression test on D16Z6?
Which fuse to cut fuel for a compression test on a D16Z6?
Old May 19, 2005 | 05:54 PM
Luserkid's Avatar
Default Re: Which fuse to pull for compression test on D16Z6? (discrete)
ecu fuse under the hood.
Old May 19, 2005 | 05:59 PM
komat's Avatar
Default Re: Which fuse to pull for compression test on D16Z6? (Luserkid)
the fuel pump is good enough
no need to pull ecu
unplug dizzy and fuel pump
Old May 19, 2005 | 06:03 PM
Hybrid96EK's Avatar
Default Re: Which fuse to pull for compression test on D16Z6? (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">the fuel pump is good enough
no need to pull ecu
unplug dizzy and fuel pump</TD></TR></TABLE>
Why go through all the effort to "unplug" the fuel pump? Or even pull the fuse. Just disconnect the injector clips and undo the dist. Be done.
Old May 19, 2005 | 07:12 PM
95DxSi-R2
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">ecu fuse under the hood. </TD></TR></TABLE>
lol
Old May 19, 2005 | 07:17 PM
95DxSi-R2
Guest
Posts: n/a
Default Re: Which fuse to pull for compression test on D16Z6? (95DxSi-R2)
unless the comp. doesn't have anything to do with the starting circuit.
Old May 19, 2005 | 10:20 PM
komat's Avatar
Default Re: Which fuse to pull for compression test on D16Z6? (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">
Why go through all the effort to "unplug" the fuel pump? Or even pull the fuse. Just disconnect the injector clips and undo the dist. Be done.</TD></TR></TABLE>
the fuel pump fuse is easier to do then the injector clips since hte fuse is under the dash
Old May 19, 2005 | 10:40 PM
Hybrid96EK's Avatar
the fuel pump fuse is easier to do then the injector clips since hte fuse is under the dash</TD></TR></TABLE>
Heh. I guess. For me I can get injector clips off just as fast as a fuse and I don't need to climb under the dash.
Old May 20, 2005 | 12:51 AM
Morning Call's Avatar
why not just the ecu? proly the easiest
duggy
30
Oct 4, 2005 07:14 AM
O16581724 5 2 5
Sep 25, 2005 09:16 AM
BlueShadow
25
Jul 8, 2005 09:43 AM
jbiggsSE
Jul 16, 2004 06:41 AM
Tad
Jan 31, 2004 07:26 PM
