Fuel pump is not kicking on
Changed the main relay, can't bolt it up because the threads are stripped.
Changed the fuel pump. ECU Fuse was blown so I replaced it and the fuel pump still doesn't kick on.
Is there a FUSE for the fuel pump? I cannot find it for the life of me.
Re: Fuel pump is not kicking on (duggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duggy »</TD></TR><TR><TD CLASS="quote">
Is there a FUSE for the fuel pump? </TD></TR></TABLE>
yes
yes
cute little bastard
I thought the "fuse" is the main relay. Not sure though
edit: I remember the same thing happened to my friend, and I fucked with the black fuses under the hood and it just worked. I was like WTF?
Re: (duggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duggy »</TD></TR><TR><TD CLASS="quote">Under the hood or under the dash?</TD></TR></TABLE>
Need more information huh? What year and model?
Re: (duggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duggy »</TD></TR><TR><TD CLASS="quote">92 CX hatch with a 95 GSR swap.</TD></TR></TABLE>
If it has an srs system, it's one of the two fuses in the srs subfuse box on the upper right side of the under dash fuse box.
Re: (duggy)
Under the Dash:
Under the Dash:
Re: (DXhatchBack93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DXhatchBack93 »</TD></TR><TR><TD CLASS="quote">Where can i get a new fuse for it do you know?</TD></TR></TABLE>
Im pretty sure hardware shops have them, auto stores, junk yards, friends cars. not hard to find. I just had the same problem in my '95 hatch. I ended up having to change the under driver side dash fuse box and the one under the hood. I have a ton of fuses now that are missing. I would ask a friend for one and then put it in and try it incase that thats not the problem.
I wish you luck
I wish you luck
Re: (DXhatchBack93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DXhatchBack93 »</TD></TR><TR><TD CLASS="quote">would i juss need to change the under dash one... or do i also have to change the one under the hood?</TD></TR></TABLE>
we arent even sure what your problem is so I cant really tell you what you will have to do. hit one thing at a time and try to do this stuff my process of elimination. get that fuse for the fuel pump from a friend like I said. if that doesnt work then just swap parts with a friends car one day so you know their **** works. when you get to the point where the pump primes then you know what you have to replace.
nice... i was searching for the fuel pump fuse this morning and couldnt find ****... i will look into this and buy one today
EDIT: wheres the main relay located ???
92-95 civics it's right next to the fuse box in above and in front of the hood opener...
if yours works sometimes, turn the ignition to ON and listen from where the click is coming from... it's on driver's side under dash
for 96-00, i'm not too sure... but i think it's in the same location
Re: (LVB18Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LVB18Civic »</TD></TR><TR><TD CLASS="quote">My friend had the same problem and it turned out to be the ACG fuse in the underdash fuse box.</TD></TR></TABLE>
he's right. check the ACG fuse. it will give symtpons of a bad fuel pump or main relay. it's under the dash, should just be labled ACG on the diagram
I changed that fuse with a brand new one, changed the main relay with a new one, new pump.
I'm thinking I burned out my ECU because I wired up o2 that same day? Maybe I got the two black wires mixed up. Any ideas?
