Rattling Noise From Tranny??? HELP
Old May 19, 2005 | 04:42 PM
Miniman253's Avatar
Default Rattling Noise From Tranny??? HELP
I'm having a problem with my tranny. its a EK4 cx.
When i start to accelerate from first gear, the rattling starts, but once past 2,000 rpm the rattling quits.. this goes for every gear 1-5.. LOW RPM the rattling starts.
honestly i really dont know what the problem is.. I'm assuming that its the tranny, simply because i already tried to tighten all the heat shields around my exaust piping and headers.
i was thinking it MIGHT be that i need to change tranny fluid. but i dont know how to do that.. i really need help on this one.
Old May 19, 2005 | 05:09 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: Rattling Noise From Tranny??? HELP (Miniman253)
sounds like a berring, could be trans main, throwout, ect... or even a messed up synchro, is it in every gear??
Old May 19, 2005 | 05:36 PM
Built to Spill's Avatar
el diablo
Default Re: Rattling Noise From Tranny??? HELP (EJ8VTEC)
Sounds like an axle problem. Whats the mileage on the tranny and axles?
Old May 19, 2005 | 06:29 PM
Miniman253's Avatar
yes, its in every gear at a low rpm.
Old May 19, 2005 | 06:32 PM
e jay one's Avatar
most likely a bearing in the tranny this happend to my friends lx sorta sounds like metal chunks flying around then suddenly no noise. i replaced his whole tranny but when i took his old one apart it was the main bearing.
Old May 19, 2005 | 07:39 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: Rattling Noise From Tranny??? HELP (e jay one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e jay one &raquo;</TD></TR><TR><TD CLASS="quote">most likely a bearing in the tranny this happend to my friends lx sorta sounds like metal chunks flying around then suddenly no noise. i replaced his whole tranny but when i took his old one apart it was the main bearing.</TD></TR></TABLE>
like i said, u can go in n rebuild but i wouldnt they r weak trans anyways. Drive easy n save for a swap, this is the exact reason y my car has a b16 w/ a strong gsr LSD so i dont have to worry bout the trans too much
Old May 19, 2005 | 09:32 PM
JDubbs99Civic's Avatar
I had a problem similiar to yours. A couple people thought it was main tranny bearing, and that I should just scrap it and get a new one. Everything is all good now after the swap.
Old May 21, 2005 | 08:36 PM
Miniman253's Avatar
Default Re: Rattling Noise From Tranny??? HELP (JDubbs99Civic)
thanks everyone..
motor swap does sound good!
but im planning on getting a bike after i sell it.
btw. i figured out what the problem was!...after everyone's tip, i decided to pull the headers out and put it back on snug..and i guess something was pinching and caused the heat sheilds to rattle.
thanks again everyone!
EG-evokilla
Transmission & Drivetrain
Feb 26, 2009 09:06 AM
Manolo
Aug 27, 2007 03:14 PM
J.nguyen
Jan 2, 2006 07:34 PM
JdM_HoNda
Apr 17, 2004 09:15 AM
