limited slip differential problems? need help or opinion ?????????
Old May 19, 2005 | 03:14 PM
civic99b16a's Avatar
Default limited slip differential problems? need help or opinion ?????????
i recently been installing my lsd into by b16a tranny. which i was doing at school till i ran out of time. anyways i ran into quite i few problems. i bought the lsd for 400$ its an obx racing for the 99-00 civic si. my transmission was a b16a sir-2 hydralic tranny. they told me it would fit which it did however the bearing on the b16a are a roller bearing not an ball bearing like the newer si's so i converted to the newer bearings with the correct shims. 120$ later after i press the new bearing onto the lsd i realize that the final drive gear that come off my stock diff. don't fit onto my lsd? the holes wont match up they are both 10 bolt. this is most diffently a b16a tranny i went to honda and talked to a kid who worked there and the diff he had from his b16a did look diffrent ? so if i buy a new final drive what should i ask for i know the 99 si final drive would fit on my lsd but woulnt i need a diffrent countershaft too? ive searched threads already but could only find people who ran into the same problem and the never said what they did to fix it?
Old May 19, 2005 | 03:22 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: limited slip differential problems? need help or opinion ????????? (civic99b16a)
the diff isnt for a gsr?
i know gsr final drives are bigger.
i just got my quaife in today i hope i dont run into any issues with it.
Old May 19, 2005 | 04:31 PM
Default Re: limited slip differential problems? need help or opinion ????????? (boostedcivicsir)
the diff is for the b16a most deffinetatly anyone else have any ideas like i said i think one of the b16a are diffrent than the rest of them ??
Old May 24, 2005 | 07:05 PM
has anyone ever seen or heard of this im sure i seen a past post about someone who had the same problem but i dont know what he did to solve it
Old May 24, 2005 | 09:10 PM
skunkwhat's Avatar
what do you mean by the diff looks different? one is open the other lsd?
i think that if the holes dont line up with the ring gear the diff may be bad? i think that the other b-seies ring gears have the same bolt pattern. Is there a part number on your stock ring gear you can check?
PINKIE2
Jul 21, 2015 10:58 AM
drSquish
Oct 13, 2005 08:03 AM
civic99b16a
Apr 7, 2005 11:38 AM
