No Oil Pressure Please Help
Old May 19, 2005 | 12:16 PM
elnoyl's Avatar
Default No Oil Pressure Please Help
I was driving my car down the freeway today and all of a sudden my oil light popped on. I checked my autometer oil pressure gauge and it registered no pressure at all. I quickly shut the car down within 5 seconds and pulled it to the side of the road. The motor has 99k on it and it is an h22a1. What do i do? Swap in a jdm longblock? Get it fixed? What tests should I run before deciding? All input is greatly appreciated thanks in advance
Old May 19, 2005 | 12:32 PM
Greyout's Avatar
Default Re: No Oil Pressure Please Help (elnoyl)
- check for obvious leaks, especially on the back of the block where you put your pressure sensor.
- check oil level. if low, return of normal level.
99% chance that one of these two items needed attention. once fixed, start car. if it runs fine, you're lucky. if not, get new engine.
Old May 19, 2005 | 12:35 PM
AndyD's Avatar
If the car ran for 5 sec. without oil pressure, I think you should be fine.
Sounds like a bad oil pump to me. I am not sure of the cost to replace.
Old May 19, 2005 | 12:50 PM
elnoyl's Avatar
Default Re: No Oil Pressure Please Help (AndyD)
I forgot to mention i checked the oil level and it's normal. What do you reccommend i do?
Old May 19, 2005 | 01:13 PM
98TypeSH's Avatar
full lvl then i would suspect the oil pump.
Old May 19, 2005 | 01:16 PM
eMpAtHy's Avatar
Default Re: No Oil Pressure Please Help (98TypeSH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH &raquo;</TD></TR><TR><TD CLASS="quote">full lvl then i would suspect the oil pump. </TD></TR></TABLE>
Old May 19, 2005 | 02:32 PM
Pikachu's Avatar
Nice job on stopping early before the real damage came to play.
Old May 19, 2005 | 04:54 PM
eMpAtHy's Avatar
Default Re: (Pikachu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pikachu &raquo;</TD></TR><TR><TD CLASS="quote">Nice job on stopping early before the real damage came to play.</TD></TR></TABLE>
yeah, this happened to me before, but the cause of it was different. i had a hose from breather hole hooked up to the piping between my compressor and filter. every time i hit boost it would pull out out and into my compressor. that is why i guess i always smelled oil burning. after 1500 miles i was wondering why the hell my oil light came on. i barely drove because i was half a block away from kragens. pulled in the parking lot and threw in 2 bottles of oil and it was back to where it should be. did an oil change later and i cut the hose in half and ziptied the part of the hose that was connected to my compressor/filter piping.
Retribution
Apr 1, 2009 06:22 PM
eg6madness
Sep 26, 2008 02:32 PM
EARLdaSQUIRREL
Sep 2, 2007 04:40 PM
sk8rmike
Sep 7, 2003 01:34 PM
vti-R
Jan 31, 2002 05:06 AM
