anybody else have shifter rattle?
Old May 19, 2005 | 11:25 AM
Brownjd's Avatar
Default anybody else have shifter rattle?
when i rev all the way out between 6500-7500rpm, i get this really annoying loud rattle from the shifter. i got under the car thinking it was just where the shifter bolts to the linkage, but it was tight, even tightened it some more and checked the other bolts down there. still same rattle. anyone else had this and got rid of it?
Old May 19, 2005 | 11:32 AM
vegaskurt's Avatar
Default Re: anybody else have shifter rattle? (Brownjd)
Is there any play with this shifter? can you move it to the left or right more than an inch?
Old May 19, 2005 | 11:49 AM
Deetz's Avatar
Crazy Honda Guy
I got that problem when i installed a short shifter. To fix the problem, i got underneath the car and grinded down the part of the shifter that was rubbing, problem fixed.
Old May 19, 2005 | 12:07 PM
Brownjd's Avatar
Default Re: (Deetz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vegaskurt &raquo;</TD></TR><TR><TD CLASS="quote">Is there any play with this shifter? can you move it to the left or right more than an inch?</TD></TR></TABLE>
in nuetral? yeah it goes back and forth
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deetz &raquo;</TD></TR><TR><TD CLASS="quote">I got that problem when i installed a short shifter. To fix the problem, i got underneath the car and grinded down the part of the shifter that was rubbing, problem fixed.</TD></TR></TABLE>
it's the stock shifter, and not rubbing the exhaust or anything
Old May 19, 2005 | 12:11 PM
2fast4udude's Avatar
Default Re: (Brownjd)
could be a boot coming apart? the force on the shifter at those rpms COULD cause rattle, if one of the boots is torn or wearing out it COULD cause it to rattle.... i'm just thinking of things that could cause it, i dunno for sure....
Old May 19, 2005 | 12:14 PM
Brownjd's Avatar
Default Re: (2fast4udude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fast4udude &raquo;</TD></TR><TR><TD CLASS="quote">could be a boot coming apart? the force on the shifter at those rpms COULD cause rattle, if one of the boots is torn or wearing out it COULD cause it to rattle.... i'm just thinking of things that could cause it, i dunno for sure.... </TD></TR></TABLE>
that's actually what i was going to look into. i wonder if the boot is so ripped that the shifter is actually vibrating off the body where it comes thru. if i hold the shifter with some pressure it won't rattle.
Old May 19, 2005 | 12:24 PM
Outsane's Avatar
Mine used to rattle against my exhaust...
Old May 24, 2005 | 02:55 PM
Default Re: (Outsane)
whats the verdict? get it fixed or atleast take a look yet? i'm curious
Old May 24, 2005 | 03:02 PM
Gearspeed-Performance's Avatar
Check your exhaust system to see if the rattle is coming from one of the brackets maybe? Do you feel a vibration on the shifter at the listed RPM's?
Old May 24, 2005 | 05:54 PM
Super79Dave's Avatar
Default Re: (GearSpeedEF9)
you may be hearing the synchro's in the tranny rattling. mine did that it got very annoying in 5th on the highway so i junked it and replaced the tranny.
Old May 24, 2005 | 08:40 PM
fourthgenhatchB17's Avatar
Default Re: (Super79Dave)
I know my skunk2 shift **** has a slight rattle to it at certain rpms...friggin annoying.
Old May 25, 2005 | 06:53 AM
crxxor's Avatar
I'm laughing because I just cured the prob on mine (annoying as hell sound). I was actually two things with me. First, one of the rubber washers had dry rotted, which caused the shifter to vibrate against the linkage. And I also had a cracked input bearing ( which you should hope you don't). Hope this helps.
Extreez
Dec 13, 2007 08:09 PM
vwtohonda
Aug 7, 2006 08:55 AM
EGhatch33
10
Apr 27, 2006 10:03 PM
CTR-GSR
Feb 24, 2006 09:47 PM
Dohc.MAD
12
Mar 30, 2005 09:31 AM
