99' integra GSR timing belt help
Old May 19, 2005 | 12:52 AM
dragerlv104's Avatar
Default 99' integra GSR timing belt help
I am trying to change my timing belt, however, I seem to have some problem getting the tension correct. It ends up too loose and everytime I try to install it moves the cam sprockets off the TDC Can anyone who is experienced give me some clever tips on how to change this bad boy effectivly, that is, getting the proper tension and not moving the sprockets? Any advise is appreciated. Thank you.
Old May 20, 2005 | 12:51 PM
draglv104's Avatar
Default Re: 99' integra GSR timing belt help (dragerlv104)
Someone must know how to change a timing belt.
Old May 21, 2005 | 10:44 AM
Come on man. Some one has to know something about changing timing belts on B-series engines.
Old May 31, 2005 | 12:15 PM
Built_For_Boost's Avatar
When both cams are in TDC, there should be holes on top of the camshafts. These holes are used to lock down the cam shafts. Use a nail or bolt to lock them down before installing the belt. When your done, don't for get to take out the nail or bolt.
blklabel44
Feb 1, 2010 02:23 AM
95accordh22a
May 10, 2005 07:43 AM
95GS-R
May 22, 2002 02:19 PM
