smoking while only in vtec and some times when first start help!!!!!!
Old May 18, 2005 | 07:16 PM
nsiag04's Avatar
Default smoking while only in vtec and some times when first start help!!!!!!
i have a crx with a b16a swap and it only smokes while vtec is plugged in and i mean bad but u shut vtec off and it quits ? sometimes it smokes when first started , but harly ever , i thought it might be the valve seals but i dont know now .. please help if u have an idea or know. thank you
Old May 19, 2005 | 04:24 AM
DARTin`'s Avatar
Default Re: smoking while only in vtec and some times when first start help!!!!!! (nsiag04)
bump
Old May 19, 2005 | 04:04 PM
StorminMatt's Avatar
Smoking is generally caused by bad rings OR valve stem seals. A compression test can give you an idea of the condition of the rings. Although a compression tests does not specifically test the oil control rings, bad compression rings generally mean bad oil control rings. And compression rings are seldom good while oil control rings are bad. However, anything is possible. Regardless, I would replace the valve stem seals first since it is a MUCH simpler and cheaper proposition. This could very well solve the problem, especially since you say you have some smoke on startup. If this doesn't solve the problem, then look to the rings.
marco562
10
Nov 19, 2012 10:59 AM
2gen_tegs_rule
Jul 2, 2008 03:17 AM
RedCd5TX
May 10, 2008 06:14 AM
red teg
Oct 9, 2005 03:33 PM
DANG YO
Nov 24, 2003 04:26 AM
