help on headlights
Old May 18, 2005 | 07:15 PM
reconstructdead's Avatar
Default help on headlights
okay, i have a 92 civic si. my dims worked fine for a while....then they just went out, and only my brights work....the switch doesnt latch for the brights so i have to hold them on. the bulbs are good i just put new ones in. so im thinking it might be the wiring or the sockets? any suggestions? thanks.
Old May 18, 2005 | 07:17 PM
98oRange's Avatar
Default Re: help on headlights (reconstructdead)
sounds liek fuse. check your fuse. I cant remember the number... should be indash one under the steering wheel. sorry
Old May 18, 2005 | 07:20 PM
98oRange's Avatar
Default Re: help on headlights (98oRange)
it should be the 2 10ampers that are sitting by the 15 amp radio one. i belive one is left and the other is right.
Old May 19, 2005 | 09:30 AM
tried those fuses...both of them are good, still no dims.
Old May 19, 2005 | 09:41 AM
Deluzional's Avatar
Could be a possbility you shorted your wiring for your lowbeams
Old May 19, 2005 | 11:27 AM
honda etr (vw)'s Avatar
son if you had a b-16 22d 32pbhs batery you would have no problems son
Old May 19, 2005 | 12:11 PM
dantastic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reconstructdead &raquo;</TD></TR><TR><TD CLASS="quote">okay, i have a 92 civic si. my dims worked fine for a while....then they just went out, and only my brights work....the switch doesnt latch for the brights so i have to hold them on. the bulbs are good i just put new ones in. so im thinking it might be the wiring or the sockets? any suggestions? thanks. </TD></TR></TABLE>
seeing as your switch is already busted, you might want try replacing it.
shauny2times
Jan 12, 2009 08:16 AM
SiB16A
14
Mar 7, 2007 02:24 PM
sockvtec
12
Oct 19, 2005 09:54 AM
LSeeper
Dec 23, 2004 12:34 AM
It's the L
Sep 3, 2002 05:44 PM
