Headlight problem 92 hatchback si...
When i turn on my headlights, it does not come on right away. It takes about 2-5 mins then it comes on. Anyone have any idea why this happens? Any Help is appreciated. It gets annoying at night time when i got to go somewhere, but have to wait for my headlights to come on before i drive TIA
Re: Headlight problem 92 hatchback si... (SiB16A)
check if its grounded properly. my friends used to work then sometimes it didnt, cause the ground was loose.
Re: Headlight problem 92 hatchback si... (DSRxNATE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSRxNATE »</TD></TR><TR><TD CLASS="quote">check if its grounded properly. my friends used to work then sometimes it didnt, cause the ground was loose.</TD></TR></TABLE>
the ground wires on the headlights correct?
both.... check all grounds. theres also im guessing what its called "relay" it should be grounded and mounted on the side.
Re: Headlight problem 92 hatchback si... (DaveSi677)
Thanks guys im gonna check the grounds, if anyone else can put their input in just holla. Thanks
Re: Headlight problem 92 hatchback si... (pkdog167)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pkdog167 »</TD></TR><TR><TD CLASS="quote">LOl nice headlight, could be the relay
*EDIT I hate people post a sec before I did </TD></TR></TABLE>
your not the only 1....... i hate that crap also... ohwell all to a good cause.
i cleaned the ground for the headlight. It actually turns on within 1 minute now. lol the grounds iin the motor have all been replaced when swap was done....
Someone told me to check the headlight switch it might be bad....thanks though dsr
