Broken Axle?
Old May 18, 2005 | 06:22 PM
5200BB6's Avatar
Default Broken Axle?
sup guys, last night i was driveing my bb6 and as i was shifting from 1->2...the car hessitated and then cut off..well i let it coast for about 50 yrds...and tryed to start it back up..it started on the first try...but when i tryed to put it in gear..all i heard is the loud grinding sound..(if i hold the clutch it stops) no matter what gear i shift it in to i will not move.(and i hear the grind)....now, normaly when i put the car in a gear and let the clutch off quick..the car will cut off..well now when i let off the clutch..the car stays running.. also the cv boot (rod) spins on the passenger side, but the driver side dosen't..and the yellow abs light is staying on... this is a 97 prelude base, it has been lowered, no engine mods, all stock..only 84k on the car..anybody knows whats wrong?..thanks.
Old May 18, 2005 | 08:15 PM
PrettyLude's Avatar
bump for some answers
Old May 18, 2005 | 08:45 PM
EFB16ACRX
Guest
Posts: n/a
Default Re: (PrettyLude)
sounds like axle to me
Old May 19, 2005 | 03:47 AM
5200BB6's Avatar
Default Re: (EFB16ACRX)
bump^ for help with this.
Old May 19, 2005 | 05:59 AM
thehondaguru's Avatar
Default Re: (5200BB6)
try taking off a damn wheel and looking at your axles
Old May 19, 2005 | 02:54 PM
5200BB6's Avatar
Default Re: (95 lude)
whats the point in takeing off a "damn" wheel...if the cv joint is spinning???...i think i said bump for help...<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5200BB6 &raquo;</TD></TR><TR><TD CLASS="quote">bump^ for help with this.</TD></TR></TABLE>..yep..i did...i dont think ur comment was very helpful...admin lock and delete this post please...thanks..
Old May 19, 2005 | 04:54 PM
OK heres your help....Change it and all your problems will go away!
Stealthyy
Transmission & Drivetrain
Jun 28, 2013 03:09 PM
euroborn1
Jul 10, 2008 03:12 PM
dthug
Feb 14, 2007 03:43 PM
MrPotatoeHead
Oct 23, 2005 07:17 PM
turbocivic0618
Oct 10, 2005 10:53 AM
