heeeeelp me...suspension
i brought it to hte local shop and had them break the front ones lose but when they did the rear they said that the bushing was turning with the bolt...should i still try and muscle them out?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4door_demon »</TD></TR><TR><TD CLASS="quote">1/2" Breaker bar, 2 foot hollow pipe
It will break free.</TD></TR></TABLE>
Not usually a good idea with seized bolts, chances are you'll rip off the head of the bolt before the bolt comes loose.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatCivic »</TD></TR><TR><TD CLASS="quote">i brought it to hte local shop and had them break the front ones lose but when they did the rear they said that the bushing was turning with the bolt...should i still try and muscle them out?</TD></TR></TABLE>
Tell them to put a wrench on the other side to hold it so they can break it loose with the gun.
You need new bushings, the same exact thing happened to me on my rear suspension. I think it was like $25.00 for the new bushings and then an hour of labor. I think it came out close to $100.00 when I was done.
yeap you need new bushings .. the rubber ish no good no more..
if you have more money now would be a good tyme to look for a lca with
sway bar bolt hole, if you already have it disregard.
oh yeah, blow torch that sucker out .
igo4bmx
13
Jan 17, 2004 11:13 PM
