DEL SOL SWAP
Old May 18, 2005 | 12:39 PM
roosta 1's Avatar
Default DEL SOL SWAP
DOES ANYONE KNOW IF THE ENGINE MOUNTS FROM MY DEL SOL SI WILL MATCH THOSE FROM A GSR MOTOR OR WILL I HAVE TO CUSTOMIZE THEM TO FIT? IF I HAVE TO BUY NEW MOUNTS FOR THE ENGINE SWAP WHAT COMPANY MAKES THEM?
Old May 18, 2005 | 12:44 PM
WildPig's Avatar
Default Re: DEL SOL SWAP (roosta 1)
#1: Turn off capslock, it's really annoying......
Hasport makes motor mount kits that you will most likely need to buy, your d-series mounts will not bolt up to a b-series. If you can, try to find del sol VTEC mounts, those del sols came with a b16 stock so you know it will bolt up.
Old May 18, 2005 | 06:19 PM
MrPotatoeHead's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roosta 1 &raquo;</TD></TR><TR><TD CLASS="quote">DOES ANYONE KNOW IF THE ENGINE MOUNTS FROM MY DEL SOL SI WILL MATCH THOSE FROM A GSR MOTOR OR WILL I HAVE TO CUSTOMIZE THEM TO FIT? IF I HAVE TO BUY NEW MOUNTS FOR THE ENGINE SWAP WHAT COMPANY MAKES THEM? </TD></TR></TABLE>
Yes they will fit..... Some People dont kno how to read...
Old May 18, 2005 | 06:25 PM
WildPig's Avatar
Default Re: DEL SOL SWAP (OnE sToCk CrX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OnE sToCk CrX &raquo;</TD></TR><TR><TD CLASS="quote">Yes they will fit..... Some People dont kno how to read...</TD></TR></TABLE>
Actually........ NO they won't fit. Do you know what kind of engine is in a del sol si? A d16 vtec engine (z6 or newer y8), and you CANNOT bolt a b series engine to d series mounts ........ plain as that.
You need new mounts (del sol vtec or 00 civic si or hasport).
Old May 18, 2005 | 07:32 PM
jadugartir's Avatar
Default Re: DEL SOL SWAP (WildPig)
tru dat, i got my d16z6 block out of a del sol si.
Old May 18, 2005 | 07:49 PM
adictionbass's Avatar
VTEC COUPE has a b16, not an si
Old May 18, 2005 | 09:01 PM
soltunr's Avatar
New User
I did a b16a2 swap in my del sol a year ago and used all the d series mounts without modification. As far as using them on a gsr...I know the passenger side trans mount and the rear mount will work. I've heard people say they had to have the driver side mount from the gsr though. I Hope this info helps.
Old May 18, 2005 | 09:18 PM
Status Sean's Avatar
Default Re: DEL SOL SWAP (soltunr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soltunr &raquo;</TD></TR><TR><TD CLASS="quote">I did a b16a2 swap in my del sol a year ago and used all the d series mounts without modification. As far as using them on a gsr...I know the passenger side trans mount and the rear mount will work. I've heard people say they had to have the driver side mount from the gsr though. I Hope this info helps.</TD></TR></TABLE>
ryanjoseph
Mar 7, 2008 05:43 PM
drugyungrage1986
13
Sep 5, 2007 05:49 PM
theonecalledtodd
16
Oct 23, 2006 04:29 PM
90civichb
Jun 5, 2004 04:13 AM
