b16 head gsr block
Old May 18, 2005 | 09:10 AM
hondanut101's Avatar
Default b16 head gsr block
I was just wondering about this set up b/c i have heard that it was good as well as bad... but no one ever has said why this set up was bad or good so if you guys could help me out with some info
Old May 18, 2005 | 09:18 AM
EG6 SiR's Avatar
Default Re: b16 head gsr block (blazenswords)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blazenswords &raquo;</TD></TR><TR><TD CLASS="quote">I was just wondering about this set up b/c i have heard that it was good as well as bad... but no one ever has said why this set up was bad or good so if you guys could help me out with some info </TD></TR></TABLE>
If you use the B16 head with a complete stock GSR block, you WILL lose compression. I would just use the GSR head with the stock block and just get a B16 tranny or an ITR tranny if you can afford it.
Old May 18, 2005 | 09:33 AM
Default Re: b16 head gsr block (EG6 SiR)
thanks for the insight.
Old May 18, 2005 | 10:07 AM
qp's Avatar
qp
i'd do this setup with a turbo
Old May 18, 2005 | 10:20 AM
Default Re: b16 head gsr block (qp)
that is what i was planning on doin, b/c i was originally going to turbo a b16 but i was wantin to try another avenue. b/c i have already done a n/a b16 crx but a friend of mine just turbo'd his ls del sol and his car is wicked, but i like the vtec motors much more. any idea what the compression ratio numbers might look like? and what boost capabilities might be?
Old May 18, 2005 | 02:58 PM
qp's Avatar
qp
comp ratio is around 10:1 taht's not exact but it's around there
right now we're boosting 5psi and it pulls hard at 12psi we can't even get traction..
hondachris1994
Sep 6, 2006 06:23 PM
Part1
Jul 11, 2006 06:55 AM
eg4usdm
Feb 20, 2005 04:11 PM
EFin' Kyle
Aug 8, 2004 02:35 AM
Turbocivic94
May 25, 2004 11:10 AM
