changing head gasket.
Old May 18, 2005 | 08:00 AM
Littlegreend15's Avatar
Default changing head gasket.
i just finished my swap a few weeks ago, i've barly even had a chance to drive it because i had no exhaust and its loud as ****, i finally get my exhaust and now i'm leaking oil from the headgasket, i'm so pissed. btw its a jdm b18c in an eg hatch. anyway, the head gasket from advance auto is 64, is that any good, or should i go with oem honda? if so whats the benifit of doing so? also, i've never changed a head gasket on a vtec engine, any special conditions i should know about? thanks in advance
Old May 18, 2005 | 08:03 AM
Ricey McRicerton's Avatar
Default Re: changing head gasket. (Littlegreend15)
Buy.
A.
Helms.
helminc.com
Old May 18, 2005 | 08:22 AM
Default Re: changing head gasket. (Ricey McRicerton)
i have one *******. why do people do this? if you don't have anything useful to say shut the **** up
Old May 18, 2005 | 08:26 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Littlegreend15 &raquo;</TD></TR><TR><TD CLASS="quote">i have one *******. why do people do this? if you don't have anything useful to say shut the **** up</TD></TR></TABLE>
If you have a helms then why are you asking me what's special about changing a vtec head gasket. The helms shows you exactly what you need to do. It holds your hand and tells you exactly what to do step by step. I was suggesting you get a Helms because of the specific torque numbers you need for the head studs.
Also, watch your shitty additude. I can and will show you the door.
Old May 18, 2005 | 08:27 AM
Deluzional's Avatar
its not smart to bitch at a MOD
btw here you go https://honda-tech.com/zerothread?id=734673
Old May 18, 2005 | 08:32 AM
Kyles ej1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">
Also, watch your shitty additude. I can and will show you the door. </TD></TR></TABLE>
DO IT!!DO IT!!DO IT!!DO IT!!DO IT!!DO IT!!DO IT!!DO IT!!
Old May 18, 2005 | 08:36 AM
I'm asking for anyone with specific experience to share their insight, you obviously don't have any, so i don't need to hear from you. understood?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote"> Also, watch your shitty additude. I can and will show you the door. </TD></TR></TABLE>
i could care less about you being a mod, keep in mind that you have no real power, its just an internet forum. save the powertrip for someone else cuz i don't care, like i said before if you don't have any insight, keep it to yourself
Old May 18, 2005 | 08:39 AM
Insight? It's changing a headgasket. It should take you 2 or 3 hours, and you told me to **** off when I told you that buying an instruction manual would be your best bet so that the job didn't get botched.
I'm not on a power trip. I'd have told anyone the exact same thing that I told you, but you got all bent out of the frame about it. Now your threads locked. Go figure it out yourself if you don't need this forum.
prietito69
Apr 1, 2008 06:27 PM
d16y8EL
Mar 29, 2007 06:55 PM
djtony5
Nov 2, 2005 02:40 PM
topspeed86
Jan 6, 2005 05:18 PM
under_psi
Aug 30, 2002 09:28 PM
