idle problems
Old May 17, 2005 | 05:52 PM
sLoWrAcEr's Avatar
Default idle problems
i have a feeling this is my cam timing setting the idle so low...i advanced the ignition timing.....but imma ask all the h-t'ers......i have a b16 in my hatch....right now im running the p06 ecu...yes thats the non vtec lx ecu.....i have a chipped p28 but the chip was supposed to come in like a month ago and didnt....anyways my car idles at around 1-200 rpms......i cleaned the IACV and when i give it gas the idle trys to drop more...sometimes shuts off.....thanx h-t
Old May 17, 2005 | 06:05 PM
OneFire's Avatar
Default Re: idle problems (sLoWrAcEr)
bump, i'd like to know this as well
Old May 18, 2005 | 01:25 PM
sLoWrAcEr's Avatar
Default Re: idle problems (SOHC_Ek)
someone...cmon i have been waiting like 45 minutes for my car to warm up and idle right
Old May 18, 2005 | 01:30 PM
WildPig's Avatar
Isn't there a manual idle adjusting screw (bolt) on the TB? My d16 has it, and I'm pretty sure that most hondas also have it.
Old May 18, 2005 | 01:33 PM
sLoWrAcEr's Avatar
Default Re: idle problems (WildPig)
yeah there is but when my car warms up it is fine it idles fine but at idle when cold it idles around 100-200 rpms...shaking violently
Old May 18, 2005 | 01:36 PM
WildPig's Avatar
IACV issue? Does the idle surge at all?
Old May 18, 2005 | 05:26 PM
sLoWrAcEr's Avatar
no idle surge no vaccuum leaks...
Old May 18, 2005 | 05:38 PM
sLoWrAcEr's Avatar
up for an answer
Old May 18, 2005 | 05:41 PM
stevenlo's Avatar
are you sure its 1 to 2 hundred???
anyways try to put the right ecu in there first
then check for a vaccuum leak...
Old May 18, 2005 | 05:48 PM
sLoWrAcEr's Avatar
Default Re: (stevenlo)
when i put the p28 in it idles the same...but its only when cold....any ideas?>
Old May 19, 2005 | 08:45 AM
sLoWrAcEr's Avatar
Default Re: (sLoWrAcEr)
up up up
Old May 19, 2005 | 05:49 PM
sLoWrAcEr's Avatar
cmon h-t daamn
Old May 19, 2005 | 07:06 PM
95DxSi-R2
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sLoWrAcEr &raquo;</TD></TR><TR><TD CLASS="quote">no idle surge no vaccuum leaks...</TD></TR></TABLE>
a vacuum leak will cause the idle to go up
Old May 19, 2005 | 07:23 PM
civic_tuned's Avatar
it could be anything..
1.gasket
2.vacumm leak
3.timing
4.clean your t.b. w/ t.b cleaner
Old May 20, 2005 | 06:55 AM
sLoWrAcEr's Avatar
Default Re: idle problems (civic_type_r)
so it could be the cam timing....?
Old May 20, 2005 | 08:58 AM
spockeg's Avatar
not 100% sure on this but if your motor is a obd0 it has a cold idle vacum valve on the front of the intake mani that could have something to do with it.
Old May 20, 2005 | 09:59 AM
siregcivic's Avatar
aright i got vtec on a switch and when the car is cold and i flick it on it sounds like a mad ******* wild cam... check your wiring or unplug the vtec solinoid wire its the green clip on the exhaust cam by the distributor.
i dont know why it would do that but it sounds like the vtec is on when its cold. also try unplugging your idle air controll ( its on the back of the intake mani ) and adjust the idle screw on the thorttle body ( screw it in to lower screw it out to raise ).
also make shure you do it when its cold to check if it makes a difference
Old May 22, 2005 | 04:05 AM
sLoWrAcEr's Avatar
Default Re: idle problems (siregcivic)
yeah i dont have vtec either im running the p06 ecu....how do you hook up the "vtec switch" anyways.....and the motor is obd1...thnax
FloridaCivic
18
Feb 24, 2007 12:23 PM
ex94vtec
14
May 6, 2006 02:07 AM
DC2*Integra
Sep 20, 2005 12:51 PM
Hyaboosta
Jul 13, 2005 02:14 PM
ArchAngel Sabastian
May 18, 2002 10:44 AM
