94 not idling smooth
Old May 17, 2005 | 02:27 PM
ronqqq's Avatar
Default 94 not idling smooth
I have a 94 civic.....
When it is idling the rpms vary up and down..
Is there a idle sensor of something that makes it idle at a given rpm.
If you give it a little bit of gas it smooths out..
Thanks Ron
Old May 17, 2005 | 02:29 PM
civiccpedx's Avatar
Default Re: 94 not idling smooth (ronqqq)
that is your IACV, check to see if your throwing any cells....there is a link at the top of the page, but it is most likely that
same thing happens on my car, i hear if you take it apart there is a little screen that you can clean with carb cleaner, and it solves the problem, im just to lazy to do it.
Old May 17, 2005 | 02:39 PM
ronqqq's Avatar
Default Re: 94 not idling smooth (civiccpedx)
IACV WWhat might that be??
What do you mean by throwing cells??
I cant find the link...
Cleaning thing with Carb cleaner heheh That is right up my alley
I hope i Can get by with that!!
Thanks
Old May 17, 2005 | 03:22 PM
civiccpedx's Avatar
Idel Air Control Valve
a cell is the code your ECU sends saying something is wrong, there is a big post with helpful information at the top of the post listings
76 camaro car
Jan 20, 2015 03:20 PM
Bruce-Wayne
Sep 22, 2013 09:28 AM
Tylerjdmgsr
Dec 28, 2009 02:55 PM
