how far downstream does a wideband need be?
Old May 17, 2005 | 02:10 PM
the jdmchop's Avatar
Default how far downstream does a wideband need be?
i built my downpipe and am going to finish up my exhaust and was wondering where the best placement for it?
thanks in advance
Dann-
ps i put this in tech but no one answered
Old May 17, 2005 | 02:18 PM
vaporboy12's Avatar
Default Re: how far downstream does a wideband need be? (jdmchop)
mine is like 5 inch back from the turbo
Old May 17, 2005 | 02:41 PM
Default Re: how far downstream does a wideband need be? (vaporboy12)
thanks for the info
anyone else got different opion?
bump
Old May 17, 2005 | 03:03 PM
Turbo-charged's Avatar
i always put 2 bungs in my downpipe for widebands.....one about 5 inches or so from the turbo and one right after the oil pan....about the stock location. sometimes its much easier to just do a quick reading near the turbo with out having to jack the car up (using a dynojet o2 sensor, not something that stays in the car)
ive noticed that the closer to the turbo, the quicker the sensors wear out. im done using dyno jet o2 sensors.....ive switched to inovate for dyno use.
Old May 17, 2005 | 03:11 PM
amit's Avatar
Default Re: how far downstream does a wideband need be? (Turbo-charged)
would it affect the accuracy of the af ratio reading if you put it say little past the oil pan as compared to right after the turbo?
Old May 17, 2005 | 03:13 PM
Default Re: how far downstream does a wideband need be? (amit)
there apears to be a very slight difference.....however it is less of a difference than comparing 2 differnt gauges together.
you would be amazed how much of a difference there is between gauge manufacturers.
Old May 17, 2005 | 05:26 PM
Used2beAb16's Avatar
In the AEM UEGO install manual, it says that turbo cars or cars holding high rpms for sustained periords with high EGTs should keep the sensor 36 inches away, and n/a cars is 18 or more inches.
AEM uses the bosch sensors that alot of others use, so it should apply to all of them.
Old May 17, 2005 | 11:24 PM
Ls1 FD3s's Avatar
Default Re: how far downstream does a wideband need be? (Used2beAb16)
PLX m300 says 24" after the turbo. So thats where mine is.
Old May 18, 2005 | 10:18 AM
Kataku2K3's Avatar
Default Re: how far downstream does a wideband need be? (Ls1 FD3s)
Motec recommends within 0.5 meters (so ~20 inches) of the collector on an NA motor, and the same but from the turbo on an FI setup. On our SFWD cars running integrated EMS widebands, they're usually no farther than 6 inches from the turbo. Just my $0.02 though...
Old May 18, 2005 | 10:25 AM
NoShoes's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">you would be amazed how much of a difference there is between gauge manufacturers.</TD></TR></TABLE>
You got that right. In my experience, the dynojet sensor reads .7-1.0:1 LEANER than the innovate, zeitronix, and some of the EMS integrated widebands. Since us old schoolers are used to seeing the dynojet readout, it's easy to differentiate between the 2.
I have seen slight TIME delays based on where the sensor is located. On 600hp cars, 3 feet downstream of the turbine exit can easily translate into a 3-400rpm delay, simply because the motor is able to go through the rpm band more quickly. On a 250hp car, the difference is negligible.
Old May 18, 2005 | 11:03 AM
Default Re: how far downstream does a wideband need be? (NoShoes)
well i have a plx so i guess they recommend 20'' but i guess this is a hit or miss type deal.
has anyone ever done a test on the different locations?
Old May 18, 2005 | 01:50 PM
Ls1 FD3s's Avatar
PLX calls for 24" got the damn instructions right here in front of me...
Old May 18, 2005 | 03:02 PM
sounds cool
Old May 19, 2005 | 09:46 AM
getnasty's Avatar
who is running race gas with a wideband? I was reading and it said not to run race gas because it burns up the sensor? any truth to this?
Old May 19, 2005 | 10:07 AM
Default Re: how far downstream does a wideband need be? (bottle fed)
does plx state 24'' on NA allone or is it for either turbo or NA?
yea will using 103 hurt this sensor?
Old May 19, 2005 | 10:29 AM
Kataku2K3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bottle fed &raquo;</TD></TR><TR><TD CLASS="quote">who is running race gas with a wideband? I was reading and it said not to run race gas because it burns up the sensor? any truth to this?</TD></TR></TABLE>
All of our cars running EMSs with integrated widebands run strictly on leaded race gas (that is on the street and at the track). If you're talking unleaded pump gas (lower octane) and unleaded race gas, I highly doubt you'll see any drastic differences in life expectancy. What are you are probably refering to is the differences in leaded gas as apose to unleaded. It is said that the life of a wideband is decreased to 1/10th of its expected when leaded gases are passed over it. The unleaded average is supposed to be around 500 hours...
skaraider
Jun 8, 2012 04:41 AM
FONK
Apr 28, 2006 04:49 PM
the.hamburglar
Jun 12, 2005 03:47 PM
servion
Aug 14, 2003 08:42 AM
civic1990si
Jun 3, 2003 05:55 AM
