ding in crank pulley
Old May 17, 2005 | 02:09 PM
CaptivaBlue's Avatar
Default ding in crank pulley
my OEM JDM B16A crank pulley has a small ding in it on the outer ring (the outer retaining surface for the A/C pump). It looks like it would wear out a A/C belt prematurely. This is of no concern to me as I don't care if I have A/C at this point. What does worry me is when I install the motor and this crank pulley starts spinning quickly will this minute (smaller than a nail head and off about 1mm) be enough to put extra wear on the rotating assembly?
Old May 17, 2005 | 02:52 PM
Honda Hick's Avatar
Default Re: ding in crank pulley (CaptivaBlue)
How big of a nail head?
When I just did my timing belt on my 180k miles GSR I noticed the crank pulley had a huge piece ripped out, like 1"x1/8-1/4" on the outer edge. The engine will runs fine and it was like that for over 90k, so surprisingly it did little damage.
A little nick isn't going to do much at all and I wouldn't worry about it. I've seen them on past motors and just filing down the edges of the nick to make it less jagged will save your a/c belt.
Old May 17, 2005 | 06:52 PM
Default Re: ding in crank pulley (Honda Hick)
I'll get a pic up soon, but I'm not going to run AC so the belt isn't in danger.
Old May 17, 2005 | 07:02 PM
Honda Hick's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CaptivaBlue &raquo;</TD></TR><TR><TD CLASS="quote">I'll get a pic up soon, but I'm not going to run AC so the belt isn't in danger.</TD></TR></TABLE>
I wouldn't worry about the belt. I've seen many chipped pulleys and as long as you file the egdes of the chip down you won't have any problems at all. Even if it did wear for some odd reason, it's just a $10 belt.
black0hatch
Honda CR-V & Element
Sep 24, 2012 09:12 AM
Goomba LS
Apr 22, 2012 04:40 PM
Ryan C
Mar 25, 2004 06:30 AM
90AccordEX4Dr
Dec 10, 2003 09:04 PM
