i think i have a bad throw out bearing.
Old May 17, 2005 | 10:56 AM
tegtuner94's Avatar
Default i think i have a bad throw out bearing.
i had a shop put in a new clutch adn flywheel from act about 25k ago and when i push the clutch to **** gears in it makes a noise like maby the bearings shot or something ma be stuck in it. but the car drives fine right now.
Old May 17, 2005 | 12:06 PM
-RedneckDave-'s Avatar
Working
Default Re: i think i have a bad throw out bearing. (tegtuner94)
Did you not put a new bearing in when you had the trans off? If you didn't then you probably do have a bearing out.
Old May 17, 2005 | 07:20 PM
deserthonda's Avatar
any shop knows to replace the bearing when doing a clutch job so i am sure they replaced it now on this noise is it like a whirling noise and stays there as long as clutch is pushed in if sp it sounds like the bearing ,,,, or a squeaking noise that is there when you only push clutch in ??
Speed94
Aug 7, 2008 06:17 AM
Aron Parsons
Mar 6, 2006 09:18 PM
JFG Kevin
Jan 31, 2006 03:36 AM
