How do you tell the Type-R gearbox from the GS-R gearbox ????
I am trying to purchase a used Type-R gearbox, but they share the S80 code with the GS-R gearbox.
Is there a way to visually tell the difference between the two ???
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King Tut33 »</TD></TR><TR><TD CLASS="quote">Just look at where the axles go into the transmission. If you can see clearly through the hole then it is a LSD.</TD></TR></TABLE>
Yeah, but this only tells you if it's LSD... It could be a GSR tranny with an ITR diff...
The best way would be to check for the stamp, as BSQ has stated, or to check for the VIN (that's if it's still there)... All USDM ITR trannies should have VIN plates on them, as they were all OBD II... An ITR VIN will be a DC231 and GSR would be either a DC238 or DC239...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4U2NV »</TD></TR><TR><TD CLASS="quote">
The best way would be to check for the stamp </TD></TR></TABLE>
The stamp can be duplicated or could be deteriorated. I would prefer a GSR tranny with an LSD diff over a GSR tranny with an ITR LSD stamp on it.
This is true, that's why I also mentioned to check for a VIN plate...
If it's a USDM ITR tranny, then it should have a VIN plate, unless it's been removed for whatever reason...
</TD></TR></TABLE>This is true, that's why I also mentioned to check for a VIN plate...
aser1z
Aug 13, 2005 06:44 PM
