Greetings looking for engine advice
Old May 17, 2005 | 08:39 AM
aghastsammy's Avatar
Default Greetings looking for engine advice
Hello all. I just inherited a '89 civic DX and am thinking about swapping the engine. Was hoping for some advice on what to swap it out with. Thanks
Old May 17, 2005 | 08:43 AM
Kryogen's Avatar
First tell us more
What kind of power you looking for?
How easy of a swap can you handle?
How much can you spend?
Then some of us..not all apparently...can give you some educated advice.
Old May 17, 2005 | 08:45 AM
Autoworks's Avatar
Default Re: (Kryogen)
https://honda-tech.com/zerothread?id=637661
Old May 17, 2005 | 10:42 AM
I am an experienced mechanic so the swap it self is no problem. What I am hoping to get is advice on what to put in. Never really played around with Civic’s and so do not know what the trends are for engine swaps and mods. Would like to run upper 100’s in hp at least just do not know what is out there that will fit. Budget is not as big as I would like, 5000 at most. Thanks
Old May 17, 2005 | 12:47 PM
kid-crx's Avatar
well if u limit is 5g's u could swap a sohc (d16z6, d16y7 or y8, jdm d15b,) and boost it. or get REAL big and go dohc vtec (b16, b18c, **h22**) http://www.hmotorsonline.com go there u will find what ur looking for....imo go h22 for 5k
Old May 17, 2005 | 01:03 PM
CRX_Control's Avatar
Default Re: (supportRhondas)
go with what you can afford and what you want your car to be like.
Old May 17, 2005 | 01:04 PM
Bjorn20's Avatar
well, for 5k u can get the gsr motor (b18c) the type r motor (b18c5r), the h22a, or u can just build a b16
Old May 17, 2005 | 01:12 PM
TehMoonRulz's Avatar
Default Re: (Bjorn20)
Ill vouch for what everyone is saying. For that money you can build up a d16z6 really well, and then turbo it. With all the money left from your 5k budget you can get after market shocks/clutch/tires etc.
Or you can build up a B series, it's a bit more money, but the base hp is higher.
From the posts I've read, if you got the money to boost a d-series, dont mess with B series.
Hope you have fun with your car
Old May 18, 2005 | 11:02 AM
Default Re: (91BlueCRX)
Wanted to thank you all. Really help point me in the right direction!
Old May 18, 2005 | 11:34 AM
Bjorn20's Avatar
Default Re: Greetings looking for engine advice (aghastsammy)
i personally really hate d series, so im saying go b series
f20bHavoc
Nov 5, 2012 01:20 PM
evan22
Jun 22, 2012 09:27 AM
speed.freak
Feb 20, 2005 06:36 AM
tuned.in
Dec 15, 2002 12:50 PM
nitrousNoS
Sep 19, 2002 07:31 PM
