Cylinder head is off, How to check the Piston Rings?
I have the cylinder head off for a rebuild. I had been suspecting that my rings are worn, 72K miles on them.
What is the best way to check without tearing the block apart?
I was told by some people that the leak down test would tell me but other say it would not.
Thanks
Thanks
leak down test had been done before the head had come off and everything was cool. It burns alot of oil, just making sure it is not the rings.
I had an SMS 2.5 exhaust put on a month ago, right before the exhaust the pipes are held together with a strap not welded, for easier removal.
Anyways, when I went for a tune I was looking down there and there was oil seeping from that connection, enough that it was still wet and ready to drip.
did not think it would pass that much oil.
thanks for the replies.
if the head is off look to at the pistons and if the edges around the pistons are clean than ur rings need to be replaced. this is caused by the oil getting into the combustion chamber and cleaning off the carbon on the pistons.
Jreycrx
May 19, 2007 09:31 AM
97grnrs
Apr 10, 2007 05:12 PM
