While crusing in gear my shifter can go to neutral w/o use of the clutch?
Old May 17, 2005 | 06:01 AM
iixerOii's Avatar
Default While crusing in gear my shifter can go to neutral w/o use of the clutch?
Alright so I was driving to work today and while on the highway traffic was slowing down a bit so I let off the gas in 5th gear. While doing this my hand must of been pulling down on the shifter and after slowing down a bit my shifter goes to neutral without any use of the clutch. Is this a normal occurrence or is this a sign of a tranny going bad?
Old May 17, 2005 | 06:28 AM
be.twenty's Avatar
You can go out of gear without clutch... you can also shift into gear without clutch if you know your car well enough.
Old May 17, 2005 | 11:45 AM
Irish Integra's Avatar
Default Re: (shogun-dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shogun-dc2 &raquo;</TD></TR><TR><TD CLASS="quote">You can go out of gear without clutch... you can also shift into gear without clutch if you know your car well enough.</TD></TR></TABLE>
unknownally
Transmission & Drivetrain
11
Jul 24, 2010 03:20 AM
taimysho0
Sep 24, 2007 05:15 PM
dohcdelsol
Jan 7, 2005 10:11 PM
Propulsion
Jun 28, 2004 07:50 PM
blackhatch13
Mar 28, 2003 03:20 PM
