Please HELP NEW CAR WATER IN TRUNK
Old May 17, 2005 | 01:45 AM
low430's Avatar
Default Please HELP NEW CAR WATER IN TRUNK
Hi ALl I just bought a 98 INtegra LS anyhow I looked in the trunk today and found some water in the spare tire area, Not much a lil less than 1/8th inch but I need to know if Integras leak comonly and second of all where do they leak from and how do I fix it.
Old May 17, 2005 | 03:17 AM
97tegGS's Avatar
Default Re: Please HELP NEW CAR WATER IN TRUNK (low430)
Not commonly they don't. Start by check the trunk seal. Make sure there are no sections missing or ripped. See if its dryrotted( which I dont think this is the problem sinces its realitavely new.
Check the tailight gaskets. Mine leaks but I'm not sure if it could leak hard enough to put water in the trunk
Old May 17, 2005 | 03:55 AM
mr.beeks's Avatar
Default Re: Please HELP NEW CAR WATER IN TRUNK (97tegGS)
check the power antena drain hose
located on left side panel
check the sunrood drain hose
located on right side pannel
check for any cracks on tailights
check tailights seals....
Old May 17, 2005 | 04:34 AM
jBj's Avatar
jBj
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97tegGS &raquo;</TD></TR><TR><TD CLASS="quote">Not commonly they don't. </TD></TR></TABLE>
Leaks in integras is actually very common, especially in the rear
Old May 17, 2005 | 04:50 AM
Milanogisser's Avatar
Default Re: Please HELP NEW CAR WATER IN TRUNK (jBj)
I have no idea about dc2's but you have a DA(90-93) you def have water in your trunk....What i did to solve it was drilled a hole.Never had water since!
Old May 17, 2005 | 04:52 AM
97tegGS's Avatar
hmm, never knew that. I have a couple of friends (4+) that all own tegs with no water. Now half including myself has a tailight leaking fluid but never any inside.
Thanks for the insight. Ill keep a lookout
Old May 17, 2005 | 04:54 AM
Dan GSR's Avatar
change the tail light gaskets
Old May 17, 2005 | 07:17 AM
low430's Avatar
Default Re: Please HELP NEW CAR WATER IN TRUNK (Dan GSR)
WHere do I get the Improved Taillight Gaskets From? I read someone has better than OEM ones?
Thanks
Old May 17, 2005 | 07:51 AM
IntegraChick's Avatar
While looking for a Gen. 3 Teg. last year, I've seen a number of them with water in the trunk. No idea why the Gen. 3 have this problem. I'm thinking it's the trunk seal. If it were the taillights, wouldn't there be condensation in the taillights as well?
Old May 17, 2005 | 08:17 AM
Tone_Locs Dc2's Avatar
i hav a 95 dc2 and when it rains water gets in like crazy....tried lookin for any hole but wasnt successful...
Old May 17, 2005 | 09:27 AM
low430's Avatar
Default Re: (dc2k20)
Its the taillights seal 4sure, Where are the sunroof drain tubes located, All I see is an access for the taillights I want to check to make sure the sunroof tubes arent leaking also
Old May 17, 2005 | 09:35 AM
GG-SquadDB's Avatar
Default Re: (low430)
ragejed ...sells them on Honda-Tech IM him he will hook you up with the better than stock gaskets
Old May 17, 2005 | 09:38 AM
Marauder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by low430 &raquo;</TD></TR><TR><TD CLASS="quote">Where are the sunroof drain tubes located, All I see is an access for the taillights I want to check to make sure the sunroof tubes arent leaking also</TD></TR></TABLE>
They are behind all the plastic panels. You have to remove the rear interior panels and there are tubes that run down to the rear quarter panels. I had one in my 96 integra that came out and was draining into the trunk.
VTEC_Club's Avatar
Default Re: (GG-SquadDB)
mines an RS integra and it leaks in there all the time. This is a common problem for alot of Integras, besides getting it stolen. I gave up on where its leaking from, but I'm guessing the taillights.
Old May 17, 2005 | 09:40 AM
HGZ's Avatar
HGZ
i had the same problem a few months back. at least few gallons would end up back there after driving in the rain for a couple of days. turns out it was the taillight gaskets because i would only use 3 nuts for each taillight to keep them on. yeah, im lazy sometimes.
anyway, i decided to just use ALL the nuts for the taillights and i never got water in my trunk again..
imagine that..
Old May 17, 2005 | 10:56 AM
97tegGS's Avatar
lol.. whoda thunkit?
Old May 17, 2005 | 11:09 PM
thx a lot for yer help fellaz
Old May 18, 2005 | 04:21 PM
MaintenanceWhore's Avatar
my car leaks from the rectangle shaped vent in my left rear trunk. Behind all the panels theres a square hole in the body, and there should be some kind of cover/vent over it. mine is missing and its just a hole to where i can touch the bumper cover by sticking my hand in it. Water is channeled by the rotation of the wheel in there.
It could be Drip rails,
Taillight gasket
windows might have been removed and not installed correctly the second time.
etc.
Old May 18, 2005 | 04:42 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: (MaintenanceWhore)
Mine use to leak, and it was filling up inside the tail lights.
All I did was take some clear nail polish or you could use super glue, and fill in the line where the lens meets the black plastic.
Old May 18, 2005 | 05:22 PM
RS DC4 94's Avatar
Default Re: (FlatBlackTeg)
When i got my 3rd gen. it did the same thing...it took my a while to figure it out but it was the antena. Here the previous owner installed an aftermarket antena and installed it w/o and seal or anything.
Old May 18, 2005 | 10:34 PM
SwedBoy2999's Avatar
I have a 90 and 92 integra and both have never leaked.
98dxkoupe
Aug 29, 2015 03:43 AM
SHG_Riley
Jan 24, 2009 11:13 PM
smile_78905
Dec 6, 2008 06:34 PM
I got a honda
Dec 15, 2007 02:03 PM
95GS-R
Dec 28, 2003 03:11 PM
