car vibrates when engine under load
this is for a 97 CRV, but i don't know where else to post. Since a lot of you guys have b20s in yr car, o well..
It vibrates around 40mph cruising and engine under load. Its like the kind of vibration u will get if u r on 5th gear going 30mph. I know partly is cause the b20b engine is a weak engine for the CRV, but could it be the two front mounts that are worn.. the AC mount and the lower tranny mount. If i were to replace those, would the vibration go away? tahnks
