B16A2
Old May 16, 2005 | 01:26 PM
zerovandez's Avatar
Default B16A2
I have a chance to grab a B16A2 at a really good price. But I'd like to get more info, so please help.
It's an OBD-0 So whats needed to install in a 97 DX? The seller mentions that he suggest to 'rebuild' the engine. This consists of replacing bearings, pistons, etc... Is there a link to some DIY's on this? I'd like to rebuild it before it gets put in my car.
tampajason's Avatar
Default Re: B16A2 (zerovandez)
look for a newer motor for less frustration.
Old May 16, 2005 | 01:28 PM
92b16vx's Avatar
There's no such thing as an OBD 0 B16A2.
Old May 16, 2005 | 01:41 PM
zerovandez's Avatar
Default Re: (92b16vx)
So the guy tells me the ECU is OBD0. Now if I were to get an OBD1 ECU, will that be ok? He also claims that's it's a 2nd gen with hydro tranny.
Old May 16, 2005 | 01:42 PM
rmcdaniels's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92b16vx &raquo;</TD></TR><TR><TD CLASS="quote">There's no such thing as an OBD 0 B16A2.</TD></TR></TABLE>
That's what I was thinking too, just OBD 1 and OBD 2. B16A1 and B16A engines came with OBD 0.
Old May 16, 2005 | 01:51 PM
zerovandez's Avatar
ok, it seems as though this guys trying to pull my chain, is there any DIY's for engine rebuilding? I really want to get an engine for my car but I also want to do it right. Links will be great!
Old May 16, 2005 | 02:15 PM
rmcdaniels's Avatar
Default Re: (zerovandez)
You appear to have 2 issues, a B16 swap and an engine that needs a rebuild. For the swap you will at least need engine, tranny, mounts, axles, ECU, plus maybe some more stuff like the rear mount. You can check here for more info:
http://www.hybridgarage.com/
As for the engine rebuild, that's another issue entirely. B16 clearances are very tight, so unless you know what you are doing and have a good set of micrometers, I'd advise against it. A full swap sells for less than 1500 with an engine that is in good shape.
steebi
Aug 10, 2008 01:00 PM
Jspek9666
Aug 10, 2007 02:14 AM
grimmer
12
Feb 11, 2007 11:04 AM
LSEGHATCH
Apr 22, 2005 08:39 AM
