where is the b16a tps sensor?
So correct me if Im wrong here guys, the sensor on the throttle body is the MAP sensor correct? IF not than where is the map or tps sensor. Im throwing a code because I dont know which plug to plug them into- there both the same plug. My wiring diagram only shows me which plug is which on the harness but not on the engine. Thanks
Andrew
Andrew
j-robsDA
May 31, 2005 06:48 AM
