Got my Fluidyne....need help installing
My friend had this in his turbo teg and offered it to me for $100 which I thought was a good deal.
It has 1 big fan with no plug that is connected to the radiator pretty securely and another small fan with a plug that's just hanging there with 1 nail thing holding it in.
1. What do I do with the blue and black wires found here?
2. How do I secure this fan and keeping it from flopping around?
3. Is that small fan big enough to work or should I get a bigger one?
Any other suggestions?
TIA
TIA
Since this is a fludyne there pretty efficient so that one big fan should just work by itself. But you can hook up the secondard as the A/C fan (If you have AC). You can take your old fan plug off your original radiotor for the fan without the plug. Just strip and soilder the plug on the wires. That fan looks like it can either push or pull..Im assuming your turbo guy had it pushing..Just make sure you wire it up correctly depeding on which side you have the fan sitting. As for holding the fans up the best thing are those things that push through...thats hold the current fun up.. You could get some small screws, washers and bolts and bolt gently trhough the fins. ???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR 98 1162 »</TD></TR><TR><TD CLASS="quote">I was under the impression that stock fans will not fit with an aftermarket radiator.
those appear to be slim style fans.... if you don't have one of those stupid snail things on the front of your motor... the stock fan should work.
</TD></TR></TABLE>those appear to be slim style fans.... if you don't have one of those stupid snail things on the front of your motor... the stock fan should work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard »</TD></TR><TR><TD CLASS="quote">
those appear to be slim style fans.... if you don't have one of those stupid snail things on the front of your motor... the stock fan should work.</TD></TR></TABLE>
Even with a stupid snail...
The slimline by itself (without the smaller a/c fan) is good enough. I ran with just one fan last summer without problems. The big fan seemed to turn on on its own as soon as the A/C was turned on.
I'd remove it.
-Chris
I'd remove it.
-Chris
This: Nylon Tie Mount Kit should work.
http://www.jegs.com/cgi-bin/nc...r=361
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">This: Nylon Tie Mount Kit should work.
http://www.jegs.com/cgi-bin/nc...r=361</TD></TR></TABLE>
Zip ties and duct tape make the world go 'round.
Good find Rob
I really want my AC and don't have one of those damn snails anways. So could I still use my stock fans?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F »</TD></TR><TR><TD CLASS="quote">
I'd remove it.
-Chris
i think he was reffering to the clearance between the turbo and the stock fans. but i might be wrong.
I'd remove it.
-Chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Curt941 »</TD></TR><TR><TD CLASS="quote">i think he was reffering to the clearance between the turbo and the stock fans. but i might be wrong.</TD></TR></TABLE>
Yeah, and he's right, a turbo won't fit with a OEM fan and larger radiator, at least not with any manifold I'm aware of.
I was just offhandedly referring to the "stupid snail" comment.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR 98 1162 »</TD></TR><TR><TD CLASS="quote">Ok, so keep the fans that are on it and ditch the OEM one right?</TD></TR></TABLE>
I would keep the larger slimline, either ziptie or trash the small fan, and ditch the OEM ones too.
Since it gets to 1000 degress down here, I'll keep that dinky little fan for my ac and find some way to ghetto rig it on the radiator.
Thanks guys
Thanks guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F »</TD></TR><TR><TD CLASS="quote">I was just offhandedly referring to the "stupid snail" comment.
once the ITR is gone both of my cars will have snails.
just mounted on the side of the motor for correct wheel drive.
phaphon
12
Sep 15, 2010 09:37 PM
wfocrx
Sep 20, 2007 08:17 AM
