01 CBR 600 - need help w/ sprockets
Old May 16, 2005 | 10:31 AM
mebri's Avatar
Default 01 CBR 600 - need help w/ sprockets
I have a 01 CBR 600 F4i
I want some more torque and quicker acceleration on my bike, and im not really concerned about losing top speed. Im new to the whole bike thing and I was wondering if anyone knew details about sprockets...do I need a front and rear sprocket, different chain? what sprocket is a good size? Just looking for some more info on this matter. Thanks in advance.
Old May 16, 2005 | 12:31 PM
marmaladedad's Avatar
Generally, when you replace your chain or sprockets, you want to do them all together. Putting a new chain on worn sprockets will decrease the life of the chain. Vice versa applies for new sprockets.
A smaller countershaft sprocket (the front one) or a larger rear sprocket, or a combination of the two, nets you an increase in acceleration. You will be running higher rpms for a given speed. And, unless your speedometer is driven off the front wheel (which, for F4i's, I believe it isn't), your speedo reading will be higher.
I think most people go with -1 / +2 (front sprocket down one tooth, rear sprocket up two teeth).
Old May 16, 2005 | 12:40 PM
mebri's Avatar
Default Re: (marmaladeboy)
is there any websites you would reccommend to purchase the sprockets? and how do you know what size chain to get with a smaller coutershaft sprocket and larger rear sprocket? thanks for the info
Old May 16, 2005 | 12:45 PM
m.'s Avatar
m.
http://www.thrustcompany.com from more tq to stuntin thrust co got you covered.
mebri's Avatar
Default Re: (10SPDHuffy)
good looks
Old May 16, 2005 | 12:58 PM
Default Re: (mebri)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mebri &raquo;</TD></TR><TR><TD CLASS="quote">is there any websites you would reccommend to purchase the sprockets? and how do you know what size chain to get with a smaller coutershaft sprocket and larger rear sprocket? thanks for the info </TD></TR></TABLE>
I buy all my stuff from Terra Powersports (www.terra-powersports.com). Definitely check them out. They can usually beat most prices. With regards to the number of links you need for your chain, that can be determined when you go to size up the chain on the sprockets. It's similar to finding the right eyelet for your belt.
Old May 16, 2005 | 01:00 PM
mebri's Avatar
thanks bro
Old May 16, 2005 | 01:02 PM
.xcalibur.'s Avatar
Default Re: (mebri)
http://www.buymoto.com = Cheap prices
eg6-trans
Honda Motorcycles
40
Jul 5, 2008 10:15 PM
Gearspeed-Performance
Oct 1, 2007 10:18 AM
_SHIFT
Honda Motorcycles
Jun 21, 2007 09:21 AM
RedStarGsr
Honda Motorcycles
Dec 27, 2004 09:55 PM
TrblPinoy1
Honda Motorcycles
10
Apr 10, 2003 11:43 AM
