96+ Civic bumper/middle support/ weights FINALLY documented
Old Feb 5, 2002 | 06:36 AM
HX_Guy's Avatar
Default 96+ Civic bumper/middle support/ weights FINALLY documented
For the longest time I have alwasy wondered whatt his stuff weighs, and could never ge ta straight answer. Ive heard clamin of as much as 35 LBS for the rear bumper support
Well last night I took off my front bumper support, rear bumper support and the middle support under the rear seat (3 part piece). Also took off the rear Suspension Techniques sway bar.
The weight breaks down like this (weighed on certified FedEx digital scale):
Front bumper support: 13.65 LBS
Middle support: 21.65 LBS
Rear bumper support: 12.75 LBS
Bolts from all 3 pieces: 1.55 LBS
Total: 49.60 LBS
The Suspension Techniques sway bar weighed 9.10 LBS including all bushing and hardware, pretty damn light. I might put it back.
In total I saved 58.70 LBS...no too bad, every little bit helps.
Im going to look for a replacment for the 29 LB stock battery next
Old Feb 5, 2002 | 06:41 AM
DragII's Avatar
Default Re: 96+ Civic bumper/middle support/ weights FINALLY documented (HX_Guy)
middle support? which part are you refering to here?
Old Feb 5, 2002 | 06:47 AM
HX_Guy's Avatar
Default Re: 96+ Civic bumper/middle support/ weights FINALLY documented (DragII)
Under the rear seat...there are three pieces that bolt to the car (frame). If you take out the part your *** sits in you can see it...there are like 15 bolts holding the three pieces down. It does the width of the car.
Old Feb 5, 2002 | 06:48 AM
DragII's Avatar
hmm...how bad is it to remove that....21lbs is a lot.
Old Feb 5, 2002 | 06:53 AM
HX_Guy's Avatar
Bad safety wise..or ba as in difficult?
Safety wise, I guess it would suck it you get T-boned...thats basically why the bar is there. It also probably adds some structual stiffiness - but who needs that in drag racing
Difficult wise..its easy. The only "hard" part is pulling on the rear plastic panels to get to the 3 bolts (on each side). It took like 10-15 minutes to remove though.
I have some racing to do thos week an next week..which is why I removed all the stuff, I might put it back...Ill see.
Old Feb 5, 2002 | 06:57 AM
DR. ON POINT's Avatar
Banned
cool
Old Feb 5, 2002 | 07:21 AM
Johnny Tran's Avatar
keep the middle support at least.......the bar is there to protect the car in the event of a side impact. you will surely get seriously hurt or killed without this piece.
And no im not being "mr safety". i also have the bumper supports out. but would not consider ever taking out the middle support.
Old Feb 5, 2002 | 07:24 AM
HX_Guy's Avatar
Default Re: 96+ Civic bumper/middle support/ weights FINALLY documented (Johnny Tran)
I will (probably) put it back in a couple weeks after the races.
I have a 2000 Camaro Z28 challanging me to a race at the track..lots of people going to watch..itll be videotaped and everything...gotta do everything to get the edge
Old Feb 5, 2002 | 07:34 AM
good deal.........
good luck with that z28
Old Feb 5, 2002 | 10:03 AM
ImportechPerformance's Avatar
Hey HX where and when you going to run?? And what that you know of does the camero have done up?
Old Feb 5, 2002 | 10:21 AM
HX_Guy's Avatar
Default Re: 96+ Civic bumper/middle support/ weights FINALLY documented (MrPimpon)
Next Wednesday at Speedworld
Not sure..he says he's stock I think..its an Automatic as well.
Old Feb 5, 2002 | 10:39 AM
TurboBumblBee's Avatar
Go for it.. kill the v8.. put the saftey parts back on your car after your all done w/ the races, those bumper supports help alot if you are ever hit head on, rear ended or t-boned, thats why they are all there..
Old Feb 5, 2002 | 10:43 AM
cool ill try to be there!!
Automatic!? *chuckles*
Stock V8,.....Heavy!? *bursts out in laughter*
Promises to be another victory for the honda camp!!
Old Feb 5, 2002 | 10:47 AM
HX_Guy's Avatar
Eh...I dont know...
Automatic for V8s = good
The guy ran a 13.3 @ 107 already on street tires..he's gonna use slicks this time I believe.
Old Feb 5, 2002 | 06:36 PM
Eh...I dont know...
damn it might be a good race.. his times are comparable w/ yours... u got slicks or any other magic goodies you are gonna use one him? i would get a bottle of zex or something just to make sure.. have someone record it you can and post the video, it would be nice to see.. and good luck..
Old Feb 6, 2002 | 04:11 PM
DA6-XSi's Avatar
New User
Default Re: 96+ Civic bumper/middle support/ weights FINALLY documented (95CivicEX)
i just wanna see ur do some roadracing..
or better yet.. take a local street turn really hard
and twist ur frame.... hehehehe
Old Feb 6, 2002 | 04:56 PM
Trey's Avatar
25 Year Member
Default Re: 96+ Civic bumper/middle support/ weights FINALLY documented (DA6-XSi)
Kick some *** Val!!!
Also, that middle bar is not in the 96 CX. So leave it out.
Old Feb 6, 2002 | 07:15 PM
gamby's Avatar
Default Re: 96+ Civic bumper/middle support/ weights FINALLY documented (Trey)
Best of luck--this should be one hell of a grudge match. However PLEASE put the supports back on your car ASAP. It's a bad idea to drive on the streets without them--period. Too many soccer moms in SUVs ready to barrel into you
Old Feb 6, 2002 | 07:21 PM
seek167's Avatar
Default Re: 96+ Civic bumper/middle support/ weights FINALLY documented (gamby)
good luck , great info
Old May 4, 2004 | 06:24 PM
Nsane1's Avatar
From: West Bakalakadaka St., Durka Durka Mohammed Gihad, WMDs
Default Re: 96+ Civic bumper/middle support/ weights FINALLY documented (seek167)
Hey HX, what engine you running in that?
rick_rabies
16
Nov 27, 2010 03:50 AM
laocivic
May 3, 2007 08:40 AM
Roller_G
May 27, 2005 07:26 AM
tRex99
20
Feb 14, 2005 08:29 PM
Joey B 18C
Oct 11, 2004 07:42 AM
