96+ Civic bumper/middle support/ weights FINALLY documented
For the longest time I have alwasy wondered whatt his stuff weighs, and could never ge ta straight answer. Ive heard clamin of as much as 35 LBS for the rear bumper support
Well last night I took off my front bumper support, rear bumper support and the middle support under the rear seat (3 part piece). Also took off the rear Suspension Techniques sway bar.
The weight breaks down like this (weighed on certified FedEx digital scale):
Front bumper support: 13.65 LBS
Middle support: 21.65 LBS
Rear bumper support: 12.75 LBS
Bolts from all 3 pieces: 1.55 LBS
Total: 49.60 LBS
The Suspension Techniques sway bar weighed 9.10 LBS including all bushing and hardware, pretty damn light. I might put it back.
In total I saved 58.70 LBS...no too bad, every little bit helps.
Im going to look for a replacment for the 29 LB stock battery next
Total: 49.60 LBS
Re: 96+ Civic bumper/middle support/ weights FINALLY documented (DragII)
Under the rear seat...there are three pieces that bolt to the car (frame). If you take out the part your *** sits in you can see it...there are like 15 bolts holding the three pieces down. It does the width of the car.
Bad safety wise..or ba as in difficult?
Safety wise, I guess it would suck it you get T-boned...thats basically why the bar is there. It also probably adds some structual stiffiness - but who needs that in drag racing
Difficult wise..its easy. The only "hard" part is pulling on the rear plastic panels to get to the 3 bolts (on each side). It took like 10-15 minutes to remove though.
I have some racing to do thos week an next week..which is why I removed all the stuff, I might put it back...Ill see.
Re: 96+ Civic bumper/middle support/ weights FINALLY documented (HX_Guy)
keep the middle support at least.......the bar is there to protect the car in the event of a side impact. you will surely get seriously hurt or killed without this piece.
And no im not being "mr safety". i also have the bumper supports out. but would not consider ever taking out the middle support.
Re: 96+ Civic bumper/middle support/ weights FINALLY documented (Johnny Tran)
I will (probably) put it back in a couple weeks after the races.
I have a 2000 Camaro Z28 challanging me to a race at the track..lots of people going to watch..itll be videotaped and everything...gotta do everything to get the edge
Hey HX where and when you going to run?? And what that you know of does the camero have done up?
Re: 96+ Civic bumper/middle support/ weights FINALLY documented (MrPimpon)
Next Wednesday at Speedworld
Not sure..he says he's stock I think..its an Automatic as well.
Go for it.. kill the v8.. put the saftey parts back on your car after your all done w/ the races, those bumper supports help alot if you are ever hit head on, rear ended or t-boned, thats why they are all there..
cool ill try to be there!!
Automatic!? *chuckles*
Stock V8,.....Heavy!? *bursts out in laughter*
Promises to be another victory for the honda camp!!
Automatic for V8s = good
The guy ran a 13.3 @ 107 already on street tires..he's gonna use slicks this time I believe.
Eh...I dont know...
Eh...I dont know...
Re: 96+ Civic bumper/middle support/ weights FINALLY documented (95CivicEX)
i just wanna see ur do some roadracing..
or better yet.. take a local street turn really hard
and twist ur frame.... hehehehe
Re: 96+ Civic bumper/middle support/ weights FINALLY documented (DA6-XSi)
Kick some *** Val!!!
Also, that middle bar is not in the 96 CX. So leave it out.
Re: 96+ Civic bumper/middle support/ weights FINALLY documented (Trey)
Best of luck--this should be one hell of a grudge match. However PLEASE put the supports back on your car ASAP. It's a bad idea to drive on the streets without them--period. Too many soccer moms in SUVs ready to barrel into you
Location: West Bakalakadaka St., Durka Durka Mohammed Gihad, WMDs
Re: 96+ Civic bumper/middle support/ weights FINALLY documented (seek167)
Hey HX, what engine you running in that?
rick_rabies
16
11-27-2010 03:50 AM
