Removing Adhesive?
Old May 15, 2005 | 08:47 PM
Mr.Speed's Avatar
Default Removing Adhesive?
What is the best way to remove adhesive off your car paint? I removed my accord and V6 emblems I like the look better more tricked out! I now need to remove the adhesive off of the paint and don't want to hurt the paint. Any help?
Thanks!
Old May 15, 2005 | 09:25 PM
CiBBeasT's Avatar
Default Re: Removing Adhesive? (Mr.Speed)
I've had success removing most decals and adhesive emblems with a blow drier. Just heat it up, the glue gets warm, and peel it off.
Old May 15, 2005 | 09:52 PM
aZnAcCoRd02's Avatar
you can use automotive goo-gone, u can pick it up at your auto parts store, or im sure there are other types of adhesive remover there too
Old May 15, 2005 | 10:22 PM
Eddiebx's Avatar
yeah or a fine cut rubbing compound works too. i would first use my finger nails and scrape off all u can, then just hit it with the compound and ur set
Old May 16, 2005 | 06:43 AM
SpeedFreak77's Avatar
Default Re: (Eddiebx)
or just some rubbing alcohol.
Old May 16, 2005 | 09:19 AM
Magnaflow's Avatar
Default Re: (SpeedFreak77)
I used mineral spirits, or Acetone.... I forgot which.... but that works real well. No it did not affect the paint....
Go to your local auto parts store you will find somethin...
Old May 16, 2005 | 10:21 AM
notoriousB's Avatar
Default Re: (Magnaflow)
"goof off" - available at home depot or the like.
just rinse the area well with water after you're finished...
Old May 16, 2005 | 11:50 AM
i20ar's Avatar
Default Re: (notoriousB)
i've heard that rubbing penut butter on it gets it off. i have yet to try it myself.. the reason they said it works is becuase the oil from the penut butter does somthing that makes the adhesive slide right off.
Old May 16, 2005 | 08:26 PM
deserthonda's Avatar
use CIBBEAST advise use a blow drier have done many times works real good
Aphelion
Jul 7, 2005 04:40 PM
HamiltonRex
Jul 17, 2004 06:13 PM
EK_Stunna
Feb 18, 2004 03:45 PM
type Gendy
Dec 12, 2003 03:48 PM
Cat
Sep 27, 2002 05:13 AM
