rpm problems after head change
Old May 15, 2005 | 07:29 PM
jcivic33's Avatar
Default rpm problems after head change
After i swapped heads (b16a2 to b16a) i lossed alot of power after 5000 rpms. we checked the timing and its right, but cannot figure what 's wrong. The reason for the switch was due to bad floater arms. any suggestions?
Old May 15, 2005 | 08:04 PM
slo_crx's Avatar
Default Re: rpm problems after head change (jcivic33)
how do you know you lost alot of power? does it just not feel as strong?
Old May 15, 2005 | 08:32 PM
Status Sean's Avatar
Default Re: rpm problems after head change (slo_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slo_crx &raquo;</TD></TR><TR><TD CLASS="quote">how do you know you lost alot of power? does it just not feel as strong? </TD></TR></TABLE>
Old May 15, 2005 | 09:52 PM
turbo_b16_ex's Avatar
vtec still kicking in? is car smoking? did you set ignition correct? throwing any CELs?
Old May 16, 2005 | 10:00 AM
jcivic33's Avatar
it used to pull hard all the way to 7000. Now it struggles after 5000. you still can hear the vtec open, But don't feel it like it used to. And i failed to mention it is turboed. it happens with both my p73 and chipped p28.
Old May 16, 2005 | 10:20 AM
DelSol-B-18's Avatar
Not to jack this guys thread, but turbo_b16_ex is the oil pump still available?? I searched and didnt find nething so i thought id try messgin u here, im in NB canada. Let me know
Old May 16, 2005 | 10:38 AM
yes still available
Old May 16, 2005 | 10:40 AM
lol yea failing to mention is turbo... could be lean. what kind of tuning and injectors you got?
Old May 16, 2005 | 06:27 PM
jcivic33's Avatar
Default Re: (turbo_b16_ex)
I'm running 440 mitsubishi injectors (with resistors) with an s-afc. the corrections have been the same for a year now. And after i did the head swap is when the powerloss happened
RacinMasonC
Nov 7, 2008 12:31 AM
dylokjai
Apr 25, 2007 05:22 AM
theelemental
Feb 11, 2006 08:14 AM
1sikhatch
18
Oct 1, 2005 02:35 AM
19sec beast
May 21, 2005 11:53 AM
