Possible fuel pump problem
Old May 15, 2005 | 04:47 PM
snoochtodanooch's Avatar
Default Possible fuel pump problem
I noticed over the past few days that my car has had little power at low RPMs. the car would kind of buck a bit till it got power at around 4k rpms.
today when i was driving back to school, it died out on me for no reason as i approached a stop. I started it back up, and it had 0 power at low rpms, and even had trouble getting up to 4k with the clutch in.
I am wondering if this is symptomatic of a bad fuel pump, or clogged fuel filter or something. It seems to be fuel related because i get no power at WOT, which seems like that would not be related to O2 sensor. I wasn't getting a check engine light, but i didn't check the cels because i didn't have my little paperclip handy. I will check it tomorrow, but just let me know what you guys think it could be.
Old May 15, 2005 | 05:31 PM
JV's Avatar
JV
Who?
Default Re: Possible fuel pump problem (snoochtodanooch)
Main Relay?
Old May 15, 2005 | 05:52 PM
Default Re: Possible fuel pump problem (JV)
isn't the main relay the problem with pre 92 vehicles? Sorry, i have a 94 with an edelbrock kit.
Old May 15, 2005 | 05:57 PM
JV's Avatar
JV
Who?
92+ also have a main fuel relay located under the dash (driver side). I have witnessed the same type of problem you described from the main relay starting to fail. Just another thing to add to your checklist.
Old May 15, 2005 | 09:46 PM
Hurricane's Avatar
main relay
Old May 15, 2005 | 11:12 PM
weird, i have never heard of or had relays fail. Anybody got a good link to a tutorial or would be willing to offer some advice. If i were to look at the wheel sitting in the car, the relays are to the left of the wheel under correct? I guess i will just have my pops run me over a relay to see if it helps the situation.
Old May 16, 2005 | 08:35 AM
716pro's Avatar
keep the info coming, i have th same prob.
Old May 18, 2005 | 05:43 PM
anybody have a schematic so i know where this relay is, i just want to make sure i am not wasting my time before i head out to walk 5 blocks to my car.
Old May 18, 2005 | 06:39 PM
JV's Avatar
JV
Who?
Looks like this:
It's located right around the hood release/fuse box area under the dash. Usually a grey color.
Old May 18, 2005 | 09:00 PM
thanks alot.
Old May 22, 2005 | 12:53 PM
it wasn't the main relay. i did replace it anyway though. I also went and replaced my fuel filter and my 02 sensor and the problem went away. I also went to colder plugs, but that was really just due to my turbo kit and for no other reason. I think it was really the o2 sensor that fixed the problem. No more bogging.
Old May 22, 2005 | 01:03 PM
TsukubaDreams's Avatar
Had the same prob. Fuel filter, rotor cap, spark plugs, and seafoam fixed it. No probs since. Good Luck.
turbogsrbaby
Apr 6, 2013 02:35 PM
chishotm
Jun 26, 2012 09:46 AM
ALL MOTOR DA
35
Aug 18, 2006 09:44 PM
stuckinhell
Mar 16, 2006 09:51 PM
Combustion Contraption
Jan 5, 2005 05:57 PM
