rattling
90 hatch dx, When I have it in neutral and the e-brake is on and the clutch is in it sounds pretty smooth then when I let it out (the clutch) it starts rattling a little bit. Is this normal?
eh same thing with me, does it rattle in 1st and 2nd gear also? Something is loose in the engine, i was gona DIY with some friends but i fergot to do it. i fergot what it was, when i find out i'll let u know.
well see the whole damn car rattles like **** when I drive it. Not way to bad but ya know just a bit more than I expected, but yes it does rattle in 1st and 2nd then its smooth in 3rd. Also I think I'm missing a pulley for my ac compressor belt. theres only two pulleys, one is the compressor and the other is the pulley that runs it. The manual had a pic with three pulleys and there is a bolt that looks like its just missing a pulley so that it can adjust the belt. I'ma go take some pics of it and I'll post them tomorrow.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fkguitar »</TD></TR><TR><TD CLASS="quote">90 hatch dx, When I have it in neutral and the e-brake is on and the clutch is in it sounds pretty smooth then when I let it out (the clutch) it starts rattling a little bit. Is this normal?</TD></TR></TABLE>
like, quiet w/ clutch pushed in, whirring/noisy with it out but in neutral?
check your tranny fluid-
if ok, input shaft bearing is probably on it's way out sometime in the future.
prolly take a lot more with it when it goes, but it usually gets pretty bad before it finally packs it in.
it mite just be your Throw out bearing. cause i know in the morning when i go out to start my car up and let off the clutch ill hear a little noise but it doesn't last long for me
um, my 84 cavalier had the same problem which is 7 years older than my civic and i took it to the shop and since then when i brake its actually smooth
and to be a smart ***, my civic is 14 years old
****... im only 3 years older than it
Ef4doorwagon
Jun 15, 2014 06:15 PM
