Valve clatter until car warms up, then none
Almost exactly what the title says, my car sounds pretty crappy when I first start it up with alot of clatter, but then once it warms up, it sounds normal. This problem started after my cams, springs, and retainers were installed. The valves were adjusted already, what else could it be?
Sounds like they are not adjusted correctly. Or you could have slight piston slap which could also go away when the car it warmed up.
I thought about a piston slap, but wouldn't it go against, "things expand when they get warmer"? I just couldn't think of a logical explanation for why it'd be there when cold, but not when warm. Also, I just did a compression test @ WOT and came up with the following results:
1: 235
2: 235
3: 230
4: 235
Seem like good numbers?
1: 235
2: 235
3: 230
4: 235
good compression,assuming your block is built, if the rings are gapped looser, when its cold it'll make alot of noise.. if its just stock, then its something within the head, maybe that valvetrain you selected is just loud, maybe that could be what you are experiencing.
Boost2NA
Dec 4, 2010 12:20 PM
